Results 1 to 13 of 13
Thread: NA Cosworth 12.5:1 pistons - what fuel?
    Spanner Monkey glenn666's Avatar
    Louth,Ireland
    323
    I have a fairly mildly tuned N/A YB here using Wossner 12.5:1 pistons. The heads been ported and is running Newman cams but otherwise the engine is mostly standard.
    It wouldn't start on ordinary fuel and I've been told to run race fuel mix in it. It runs OK on the race fuel mix but is there any possibility of safely tuning it to run on road fuel? It's on 45 DCOEs if that makes any difference.
    3,236
    Re: NA Cosworth 12.5:1 pistons - what fuel?
    Running super unleaded may be possible with a shed load of reduced timing. What you need is octane and pump piss just don't have enough. You could use aviation gas which is either unleaded or low lead and 100+ octane but not really convenient on a road trip LOL! Whatever you use, the timing will need setting for the fuel - a decompression plate may be a better option?
    25,110
    whether its on low octane, super unleaded race or rocket fuel, it should still start, theres something else wrong other than fuel quality
    Louth,Ireland
    323
    Appreciate the replies lads. Do you think with carbs jetted to suit & timing adjusted correctly, would it be safe to run on super & octane booster maybe?
    25,110
    i would of thought so
    Jul 2010
    South Wales
    4,689
    221
    i run an n/a engine with a 12.5-1 cr and i run shells V-Power Nitro+ as that is what i mapped the car to. i have done loads of track days and road mileage in the car and it is great. it doesn't like 'lesser' fuels at all which is a shame as v power costs a bomb. But if you want the full bang lout of an engine you have to run decent fuel. I could have went down the octane booster route as well but cost would start getting out of hand then.
    If the engine won't start on normal pump then there's something fundamentally wrong. Start with checking fuel, spark and ignition timing before going out and buying expensive high octane fuel. We ran these type of engines in the late 80's and early 90's and they were one of the best starting engines we have had. You have a problem somewhere and it's not the grade of your fuel.
    25,110
    spot on, you just said it better than i did
    Louth,Ireland
    323
    There is no fuel available in Ireland apart from standard pump fuel unfortunately.
    Thanks for the info lads. I did talk to one well renowned tuner over here who said it wouldn't be possible to run on road fuel but I will have a look around see if I can find anyone more capable or interested in sorting it out.
    Jul 2010
    South Wales
    4,689
    221
    Quote Originally Posted by glenn666 View Post
    damn that's a shame. what about a 75% road fuel to 25% race fuel? one of the boys just bought a stage car from Ireland and is running that in his.
    25,110
    it wouldnt be that difficult to machine a bit off the pistons to drop the compression, and/or simply use a thick head gasket
    Spanner Monkey Mkdu's Avatar
    Oct 2009
    417
    14
    also have a cossy N/A, run on wossner, 98 octane belgian fuel, mapped for that. No issue.
    Not used for competition, so not really need V-power or something like that, plus don't want to bring such fuel from Germany !
    Engine was mapped before for 99 UK fuel, and started with our bad belgian fuel. The ignition timing was reduced from UK map to use our fuel when rebuild occured.
    Jun 2004
    Bristol
    1,494
    18
    When I go to Ireland I run std unleaded with a bottle of Millers Oils CVL Turbo in every jerry can (20l)
    This is on a N/A cossie with 12:1 compression
    In the UK I use Shell V-Power
  14. The Following User Says Thank You to GavinR For This Useful Post:
