Mk2 15" rear turrets
Hi all I have just trail fit my 15" turrets with measurements of 39" hole centre 28.5" from door seal edge 7" from roll bar hole centre to leading edge of turret also with a height of 15" from base of chassis rail to turret top! Is it correct for turret to lean in at top towards boot or should they be level?
Re: Mk2 15" rear turrets
Yep they do lean in at the top about 3 degrees is about normal
