Starting point
Installing a yestertech ignition on a 2L Zetec that is very basic. Easy initial setup and I am looking for a starting point for ignition advance at idle. Also, what is the maximum advance allowable for one of these engines.
Thanks in advance.
Rob
Re: Starting point
8 - 10 degrees usually works ok for cranking and 10 - 15 at idle. Max advance can be in high 30's - low 40's in cruise conditions.
The Following User Says Thank You to katana For This Useful Post:
Re: Starting point
If you google images, ignition maps for zetec you should get a whole heap of maps with figures that will help with getting you started.
