Right ive started rebuilding the zetec, just wondering what parts do i actually have to replace, bearing shells, water pump, gaskets(duh), con rod bolts?, flywheel bolts? anymore?
Head bolts if they're stretch ones, cambelt+ tensioner, pistons and rins if you need a rebore, but its impossible to say without seeing the condition of everything. Conrod and flywheel bolts - not necessarily, they are probably reusable, but i'd consult a manual.
One day people will stop asking 'Is that bit of your car supposed to be hanging off/leaking/on fire like that?'
oil pump, check core plugs if block looks a bit rusty looking,no antifreeze used ,cam followers,belts, tensioners,
nick
MOBILE REMAPPING KENT
yeah got the cambelt, and the bores are ok etc, so the piston rings have to be replaced reguardless i take it?
come on guys, do i really need to do the piston rings? cos theyre about 100quid and dont wanna go an buy theem unless i really need 2
cheers
Need to preform a leakdown test.
http://autos.yahoo.com/maintain/repa...ques057_1.html
http://www.carcraft.com/techarticles...ter/index.html
doesnt that mean building up the whole engine tho? nd that kit looks expensive
Look on ebay and search worldwide - About £25. You'd only need to bolt the head onto the block to use it.
dose the old motor go ----you could get it going and test it compression test---hot and then do a test with oil down the Boer----- tell you if its rings or valves ---- test the oil presser hot and cold with a test gauge there is come things you can do to tell how good the motor is--- but a real good look at the general condition of thing when you pull the motor apart-- but you will need to know what you are doing if you are to rebuild a motor like there are a host of thing you can do wrong and one can make you cry after all the money and work
by know you will have the motor reconed
I was kidding
(but I'm surprised I wasn't fairly close )
i know you where kidding dave plus im getting rid now
