Page 1 of 2 1 2 LastLast
Results 1 to 40 of 52
Thread: Capri 2.8i won't start
    Pit Crew Decade Plus User Allerton Classics's Avatar
    Feb 2007
    Liverpool
    1,662
    17
    I bought a Capri 2.8i I did the heads and now it will not start at all
    the timing is ok, spark at the leads
    Fuel is there, valve gaps ok.
    I have put a spare start valve on the plen chamber,lots of fuel at the connecting pipe.
    The Aux air device is open, I have taken it off 2 see.
    If I have mixed the injectors up would this affect it,not that it would be easy to do?
    The car has back fired once + blow'n the pipe of the warm up reg after I checked the valve gaps, but will not run at all.
    The battery is new.
    The engine ran before but after running, turned it off and could not start it again before I stripped it down.
    hope all this makes sense
    Mechanic Mr_lizard's Avatar
    Jan 2006
    Southend, Essex, Innit
    673
    Re: Capri 2.8i won't start
    Make sure the dizzy isn't 180 degrees out and recheck all the lead sequence. Make sure that the flap isn't stuck in the metering head as well (This happened to me) It won't matter if the injectors are mixed up as the K-jetronic is a constant feed system. I did have a problem with the injectors not sealing in the manifold and this caused problems, which I cured by pulling them all out and re-sealing them with siligasket.
    One day people will stop asking 'Is that bit of your car supposed to be hanging off/leaking/on fire like that?'
    Feb 2007
    Liverpool
    1,662
    17
    Took the warm up reg off and it was gunged up
    put it back on and the turn over was a bit better,
    So I put a spare one on and now it is actually firing
    well trying.
    I have tried the 180 degrees idea it is not that nor is it the sequence
    I tried widening the gap on the sparks and it made a difference but only did one bank. the book says 0.60mm 0.0025
    which is very small.
    It sounds like the timing but it is not ,plenty of fuel so it is not that.
    I have a spare dissy and eng it is out of a 4x4, the rotor arm is different, looks like a rev limter on it I will give the dissy a go. stoped for today as it is getting cold
    Jan 2006
    673
    The 2.8i should have a rev-limiting arm fitted as standard, people often fit non-limiting ones off xr4's coz they're a lot cheaper! Is the metering head flap opening correctly and not catching anywhere? What did you strip down on the engine anyway?
    Feb 2007
    Liverpool
    1,662
    17
    metering head flap,Where is this?
    I will be putting new plugs in when they arrive.
    Jan 2006
    673
    It's on the right hand side, as you look at the engine, its above the air filter, under the inlet trunking just behind where the 8 or so injector pipes connect to the metering head. If you take the inlet trunking off you should see a disc that if you push it gently should move down. When the engine is running the flap it lifted up and by inlet suction and reglates the fuel pressure/flow. If is sticking it can alter the fuel mixture and stop it starting ( or it'll shoot flames out the exhaust, like mine did!)
    Spanner Monkey mihakrapez's Avatar
    Jan 2007
    Ljubljana, Slovenia, Slovenia
    281
    18
    I had the same problem.
    After 2 days I found out that one of the previous owners rotated complete ignition for 180 degrees.
    It said on the dizzy 1 but it was 4 so spark cables were positioned wrong it had only backfired a couple of times.
    Turned it to correct position and it started first time
    Where is original rev limiter mounted
    Jan 2006
    673
    It's built onto the top of the rotor arm, it's a horibble sprung loaded thing that feels like you've flung an anchor out the car when it hits 6100rpm!
    Jan 2007
    281
    18
    Thank you.
    I have original TT ignition. ( is it possible to remove it).
    I would like to go for omex rewlimeter and 284/284 2.5K-6.5K kent cam.
    Obstacles are those frightful things you see when you take your eyes off your goal.
    Jan 2006
    673
    Yeah, I think the XR4 arm is a direct swap, just pull yours off and pop the new one on.
    Feb 2007
    Liverpool
    1,662
    17
    Finally got the car started
    I checked the metering head flap seemed to be ok
    It was the spark plugs put a new set in, I think the main problem was the warm up reg as it was bunged up and old spark plugs.
    So now I have to tighten the left bank manifold as it is blowing and set the timing and check for leaks.
    The rear break is ceased but I do not have the alloy locking wheel nut key, any ideas how to get it off.
    Thanks for the advice
    I will post pics as soon as I give it a wash.
    James
    Dave's Avatar
    Oct 2003
    Cheshire
    23,117
    Is the lock you are talking about one of those square shaped things?
    Easiest way to get them off is with a large flat bladed screwdriver. Put the blade into one of the sides of the square and turn it. Works for me, but make sure it is the biggest screwdriver that will fit in.
    Feb 2007
    Liverpool
    1,662
    17
    No it is the wheel locking nut / Hub nut
    I guess that you can buy the keys, are there lots of variants?
    James
    Jan 2006
    673
    Just get an old 12 point socket and spank it on with an FBH, or depending on the wheels you have, you can use an FBH and chisel.
    Feb 2007
    Liverpool
    1,662
    17
    Tighten the manifolds today and it started and it sounds good
    Oil pressure is at least mid way, before I reconed the heads it was no existent.
    The tappets need adjusting, but need to tighten the head bolts first.
    But sods law the starter packed up, I knew the power lead was a bit dodgy, little did I know the connector was loose as f..k inside and came off, so I have removed it and will look for a second hand 1.
    I have a pinto 2.0l one that prob will fit but it looks a bit weaker.
    The exhaust, I cannot work if it is blowing or the tubular manifolds make it sound that way
    Will strobe it and set the timing, 10 degs dose that sound right?
    Jan 2006
    673
    My tubular exhaust makes a right racket. Possibly because its blowing everywhere and a bit knackered, roll on the 24v cossie! I think the timing is meant to be 8deg, but i'll have a look at what the haynes says.
    Pit Crew bazpro88's Avatar
    Jul 2006
    sunderland
    1,051
    i got a brand new starter for 35 plus postage if u interested. got it with my capri but never had to use it
    Feb 2007
    Liverpool
    1,662
    17
    Got the starter today
    Fitted and started no probs,have set the timing and all the guages work, I can even see the petrol guage go up
    (dont know how long it will stay just above the red)
    The n/s indicator dose not work ,all the other lights and wipers do
    A bit tapity but not to bad.
    Just need to get the wheels off now and do the brakes,bought new shoes and cylinders.
    If Memory serves me right it can be a three handed job.
    The exhast sound load when I rev it ,but I think that it is a large bore up to the rear boxes.
  19. #19
    Dave's Avatar
    Oct 2003
    Cheshire
    23,117
    Capri fuel and temperature guages are only for decoration. The needles may well move about, but rarely do those movements mean anything.
  20. #20
    Feb 2007
    Liverpool
    1,662
    17
    There is the car
  21. #21
    Feb 2007
    Liverpool
    1,662
    17
    Got the locking wheel nut of
    Hammered a multi socket on and off it came
    Brakes just needed freeing and are ok but can not test drive it as not legal yet
    No mot or Tax but will take it next Friday
    Insurance is about 134.00 / 3000 miles per year
  22. #22
    Jan 2006
    673
    Titan blue, like it, looks pretty rust free too. Needs lowering......
  23. #23
    Feb 2007
    Liverpool
    1,662
    17
    I would like to stick 17" wheels on
    but whant some old skool 4 spokes
    Also I have some alloy lowering blocks that came with a mk1 escort would these fit?
    what about the fronts do I need lower springs,where would the best place be to get them?
    James
  24. #24
    Jan 2006
    673
    17" wheels won't suit the car well, old fords tend to suit smaller rims better (in my opinion!) You might struggle to get 17's under the arches too, but these look about the best of the big wheels and make sure they're the right offset though, but I prefer the 15" 7 spokes off the brooklands. The mk1 escort blocks are the same capri ones. Front springs can be lowered by cutting a coil off, but it can be hard to get it to sit level after! Try www.tickover.co.uk
  25. #25
    Dave's Avatar
    Oct 2003
    Cheshire
    23,117
    Rally Design for lowered springs. They don't cost much.
  26. #26
    Oct 2007
    middleton
    1,099
    64
    Awesome Capri there James. I recall seeing one in Droylsden,and another in Middleton near me. I had a brief chat with him as I was driving in the opposite direction. Hearing the sound of one approaching is unique,a lovely sound.
  27. #27
    Feb 2007
    Liverpool
    1,662
    17
    Tourqed the head down again seems to be ok still a bit of steam coming oil off oil filler tube.
    Did a compression test after warming the engine.
    125 psi on 2 and 4 cylinders, some bore wear so I guess that is average for a high mileage engine.
    Will take it for a mot next week.
    I think it will fail on emissions and properly some little things, as it seems solid underneath regards welding.
    All light work brakes are a bit spongy but will bleed them tomorrow and it needs a exhaust rear rubber mount the steering wheel is off centre dose not pull.
    The drivers window runners are crap as the glass drops
    do not know if I need parts or I can fix it and the sunroof dose not open not sure what that is down to.
  28. #28
    Jan 2006
    673
    My drivers window drops out too, The channel rotted away at the bottom. You'll probably need a new window. Sunroofs? Don't bother! If they open they usually get stuck or hit the roof and scrape half the paint off or they leak like a ba*tard!
  29. #29
    Feb 2007
    Liverpool
    1,662
    17
    Car failed on:
    Plate light
    Wiper blades.(new blades)
    Washer jet water not enough (so need adjusting)
    Horn fuse is ok (so maybe wiring or horn)
    rear exhaust mount,(I could not get the new one on last night so I will use the rings from halfords.)
    some welding,(I could not see any needed but not a problem for man of my caliber)
    Oh and emisions (was expected,will fit new air filter and adjust)
    So not all that bad
  30. #30
    Jan 2006
    673
    Not too sad! Where does it need welding?
  31. #31
    Jul 2004
    Reading
    1,517
    Quote Originally Posted by Mr_lizard View Post
    The XR4i has the same rotor arm
    I would bin all the igntion system and fit a megajolt. It will be a lot better and probably work out cheaper in the long run.
    Zetec Mk 1 Escort
    Mk 2 X Pack Capri 3.0S (not a copy, the real thing)
    Mk 1 XR4i
    Mk 3a Fiesta Si
    www.zetecescorts.bravehost.com
  32. #32
    Feb 2007
    Liverpool
    1,662
    17
    I have done:
    The emissions
    The water jets
    Wipers are on the way
    Horn is f..ked
    (Took it off and dose not work when a live and eath is fed from battery)
    Bulbs are gone on the rear plate light (or could be a bad earth)
    Re: the welding I can not find any problems
    it was in the back of my mind to ask to be shown the area
    but as I was given the sheet the owner said he has put yellow chalk on the area, what a load of
    So I will be on the phone on Monday.
  33. #33
    Feb 2007
    Liverpool
    1,662
    17
    Rear exhaust mount done
    Rear plate lights done
    New bulbs still no diff
    Turned out to be a bad earth the only way I could get them both to work was to bolt the fitting to the car then with the second bolt hole, bolt the plastic cover over the fitting.
    As the fitting is earthed through the bolt
    Will look at it in more depth later when it passes the MOT and as the wind chill factor, it was fin cold out there
  34. #34
    Jan 2006
    673
    Yeah, mine earth through the bolts too. Ford designed them like that so they can laugh when they all stop working!
  35. #35
    Feb 2007
    Liverpool
    1,662
    17
    PassedThe MOT
    Now just got to sort the drivers window
    Tappets
    Tax
    properly sort the plate light bulbs out
    Etc...
    Will change the engine if I keep it,it is my Winter car for now
  36. #36
    Jan 2006
    673
    Nice one
    Now all together - Cosworth 24v...................
  37. #37
    Dave's Avatar
    Oct 2003
    Cheshire
    23,117
    Excellent
    What happened to the welding though?
  38. #38
    Feb 2007
    Liverpool
    1,662
    17
    Welding I did after I phoned and asked where it was.
    It stated on the fail sheet that:
    n/s front suspension component mounting prescribed area is deliberately modified which significantly reduces the original strength (2.4.a.2)
    It was the inner chassis rail engine area
    So plated it luckly it was vertical not over head
    the tester said it is not possible to hand right on the sheet
  39. #39
    Feb 2007
    Liverpool
    1,662
    17
    2003 was the last time the car was taxed
    And cleaned by the amount of dirt and algae spiders webs and eggs in the bumpers and front grill
  40. #40
    25,175
    297
    yes thats correct technically its a legal document so the sheet has to say the exact legal reason why the car has failed,
    i used to get no end of grief from in vehicle inspectorate when i was an MOT QC because one of my testers wouldnt use the correct wording but wrote whatever he thought at the time.
    if a failure sheet says " excessive play in a jiggle pin" then for the sheet to be legally correct there has to be a section in the testers manual that says to check jiggle pin and a reason for rejection that states
    bonkers i know, its just legal red tape, but it means its immpossible for them to accurately decribe stuff like corrosion
Similar Threads
  1. 2.8i capri cold start injector
    By Stevie in forum Wants
    Last Post: 29-05-2006, 11:45
  2. Start Again
    By Sharon in forum The Muppets
    Last Post: 28-02-2006, 09:09
  3. A new start
    By Bodney in forum Message Centre
    Last Post: 26-10-2005, 21:43
  4. where to start
    By MK1cooltina in forum The Technical Section
    Last Post: 16-08-2005, 09:40
  5. She won't start. Please help.
    By magic55 in forum The Technical Section
    Last Post: 31-01-2005, 21:03
