i have stripped a frst not so long back to swap my rst to efi i have all the things i need and i also wanna swap the clutch as ive just bought a paddle type so swapping to the frst flywheel could be done at the same time also my block has the hole for crank sensor or flywheel pick up u no what i mean but is it really worth all the hassle as i would need to change head which i would need to put my piper cam in then all the wiring just wondering if its worth it ? and also if it is does any 1 know any good sites for the wiring side as i cut the wires going in to the bulkhead underbonnet stuff looks ok so should i do it or should i leave well alone well shes running well ???????????
