Results 1 to 3 of 3
Thread: busted pistons
    Oct 2011
    uk
    168
    20
    busted pistons
    Click image for larger version Name:	p1.jpg Views:	101 Size:	106.1 KB ID:	80907
    so what caused this then ?
    standard internally duratec, with unknown mileage, running throttle bodies
    top of the piston its clean, with no signs of knocking, plugs looked good too
    the other 3 pistons are in a similar shape, just not as bad
    3,641
    Re: busted pistons
    Too high compression, rings picking up, incorrect ring gap.
  3. The Following User Says Thank You to Erikmex For This Useful Post:
    Re: busted pistons
    could just be fatigue failure from high miles, but probably helped a coked up engine either detonataing a bit or pinking like hell, in std form with miles on them these engines tend to pink would be even more so on throttle bodies especially if the mapping isnt quite right or its had some poor quality fuel through it
  5. The Following User Says Thank You to Graham For This Useful Post:
