Results 1 to 6 of 6
Thread: Yb coil pack conversion
    Feb 2011
    ireland
    Hi
    Anyone know what leads to use on yb coil pack conversion(ford coil pack)The original leads are very loose in the coil pack and car is going to be rallied so would prefer if they were a tight fit
    Jun 2006
    Durham, UK
    1,494
    Re: Yb coil pack conversion
    Hey Mike. I made my own up from a set of new 4x4 leads and a set of ends suitable for the Zetec coilpack. The ends came from mr-retro-leads-plugs on Ebay, for the princely sum of about £12 for the four and the set of 9mm 4x4 leads were £28 from Matt Lewis Racing (they're even cheaper now):
    http://www.ebay.co.uk/itm/COIL-PACK-...-/111681031025
    http://www.mattlewisracing.co.uk/pro...t_lewis_racing
    It was pretty easy to do, although took a while, and they fasten very securely.
    As with pretty much everything else I've done, I took a load of pictures, hopefully they'll give you an idea of how simple the process was:
    Click image for larger version Name:	P1070276-.JPG Views:	112 Size:	117.0 KB ID:	80927
    The leads as they arrive - obviously you chop off the distributor end. You want to leave around 20-25mm of the inner core exposed so that the brass electrode crimps over it properly.
    Click image for larger version Name:	P1070282-.JPG Views:	110 Size:	87.8 KB ID:	80928
    Click image for larger version Name:	P1070283-.JPG Views:	111 Size:	98.9 KB ID:	80929
    Click image for larger version Name:	P1070286-.JPG Views:	110 Size:	90.0 KB ID:	80930
    Click image for larger version Name:	P1070288-.JPG Views:	111 Size:	117.1 KB ID:	80931
  3. The Following User Says Thank You to MegatronUK For This Useful Post:
    Feb 2016
    socal
    26
    What lube did you use to slip the cable through the insulator?
  5. #4
    Jun 2006
    Durham, UK
    1,494
    It was just a can of generic white spray grease, not sure of the brand sorry.
  6. The Following User Says Thank You to MegatronUK For This Useful Post:
  7. #5
    Feb 2011
    ireland
    Thanks for the reply
  8. #6
    Jun 2004
    Bristol
    1,494
    18
    That's a very neat solution converting the leads
    My engine builder machined out the centre of the rocker cover which allows std Zetec leads to be used
