Results 1 to 6 of 6
Thread: 1982 Honda CM 250 T
    May 2004
    South Wales
    350
    Question 1982 Honda CM 250 T
    Hi all, as above, the bike is only running on one side of the twin engine.
    Could this be due to a faulty coil/rectifier?
    Thanks in advance.
    May 2004
    South Wales
    350
    Re: 1982 Honda CM 250 T
    Could this fault be due to the poor holding charge from the battery by any chance?
    Part of the furniture Decade Plus User
    RS Yod's Avatar
    Jun 2002
    North London
    10,210
    62
    No mate highly unlikely will be battery related, first do a spark test and if you dont have the tools theres always the old skool way
    Take the HT lead off, put a screwdriver into the lead as long as it touches its ok, put the opposite end of the screwdriver near something thats earthed, leave a 2mm ish gap and crank. If its sparking you will see it arc betweek the screwdriver and earth point, then you know its not electrical and its compression related.
    Also, take out the plugs and check them, swop them over see if the same bank still missfires.
    May 2004
    South Wales
    350
    Cheers Yodi.
    May 2004
    South Wales
    350
    Gave the battery a slow trickle charge today and put 2 new plugs in and fired her up. Both banks are running as they should be.
    RS Yod's Avatar
    Jun 2002
    North London
    10,210
    62
    Must have been the Plugs, could have been the battery but a lot less likely
Similar Threads
  1. Whats A 1982 XR3 Worth??
    By cjay2004 in forum General Car Banter
    Last Post: 09-11-2007, 23:39
  2. 1981/1982 Welsh Rallysprints...
    By GP4 in forum Movies
    Last Post: 26-04-2007, 10:59
  3. 1982 xr3
    By philc in forum Parts For Sale
    Last Post: 06-11-2004, 18:46
  4. 1982 BLUE LANDROVER 4 SALE!!!
    By Rsbabe in forum Parts For Sale
    Last Post: 15-04-2004, 16:16
