Re: [For Sale] Ford Type-E Rocket 4-speed transmission / gearbox with straight cut ge
Where in Germany are you located?
Check your pirvate messages!
Update: The installed tran-x gears are 2.48 - 1.69 - 1.28 - 1, very close to the stock rocket gear ratios which are 2.54 - 1.66 - 1.255 - 1
What type of engine was it mounted to? I do not recognize the bellhouse
Verstuurd vanaf mijn Moto G (4) met Tapatalk
It used to be attached to an 4A-GE and hence I dont sell the bellhousing unless you also want to use this transmission with an 4A-GE but then the price goes up.
