Results 1 to 14 of 14
Thread: Talk to me about mk2 rear disc conversions
    Jun 2012
    ireland
    1,158
    Hi Folks,
    I’m hoping for some opinions and guidance on this. I’m currently running 9” drums on my mk2, which I use for autotests and lanes rally type events etc, so as you can imagine the handbrake is extremely important and must lock instantly with minimum effort.
    The drums have been ‘ok’ to date, but somewhat unreliable. When they get very hot, the efficiency of the handbrake drops off considerably, and the weekend just gone after I fitted new shoes the self-adjusters kept over adjusting by themselves and binding on the drums leading me to having to strip the rear brakes twice mid event. So, im getting pretty sick of drums.
    So, rear disc conversions for English axle –
    I’ve done as much research as I can, but as usual you get so much conflicting information it’s hard to know what to believe.
    Ive heard sierra Cosworth calipers, mk3 fiesta front calipers, vw golf calipers (?) etc etc.
    I was looking at the kit that motorsport tools has with the willwood powerlite calipers but forking out over 500 quid is just not an option at the moment.
    So what’s my options with what’s available today ?
    Oct 2015
    Essex
    347
    33
    Discs with a hydraulic hand brake may work but cosy calipers n fiesta discs aren't the best 😳on my atlas the brakes work well as I've got a cosy hydraulic booster but the cable hand brake is just ok
    3,641
    Re: Talk to me about mk2 rear disc conversions
    The mechanical handbrake on rear disc calipers is crap, drums are better unless you fit a hydraulic handbrake as mentioned above. You need more pressure to grip the disc than can be pulled with a cable, drum shoes have a mechanical advantage due to the rotational force of the drum pushing the leading shoe.
    Jun 2012
    ireland
    1,158
    sorry i just re-read my post, and i may have mislead everyone - i have a perfectly good vertical hydraulic handbrake fitted with AP cylinder.
    i dont even need the cable handbrake at all as my car is MOT exempt here in ireland, sorry i shoul have made that clear.
    when i used the hydraulic handbrake in anger on the first test, the handbrake over-adjusted itself and binded to the drum
    In the good old days it was Mk3 Escort discs and calipers, however they required a bias pedal box and pressure reduction valve to prevent them from locking when driven in anger. Before they became available we fitted Chrysler 180 rears, they even had a cable mechanism to comply with road traffic law.
    Sep 2004
    Ireland
    354
    18
    i have a couple of sets of xr3i calipers,if your interested in a pair.
    Jun 2012
    ireland
    1,158
    might be intersted mick, do you have disks to suit?
    I bought a new pair of XR3I discs from my local motor factors a couple of years ago.
    Sep 2004
    Ireland
    354
    18
    yes i have discs as well but new ones are not expensive proably be better in the long run to use new.pm me and i,l send you my number.
    Aug 2015
    Leeds
    767
    An axle I bought had xr3i calipers and some discs, didn't look used, think they were fit to make a complete axle. Just in the corner of the garage now, I went with cossie rear calipers and a solid disc cause I needed a Machanical handbrake, and there good, handbrake is abit naff, but I have a hydraulic one aswell, I was running type 16 2 pot fronts and never had a problem with bias I run a bias pedal box tho, I've now gone to 4 pots on the front, not been on track since I'm going to Croft next Tuesday.
    Mar 2003
    TRURO
    5,250
    246
    Also worth noting fitting rear discs will add an extra 10mm at least to the overall axle width so watch your tyre clearances.
    Plymouth
    899
    10mm each side
    Quote Originally Posted by Warrior View Post
    An axle I bought had xr3i calipers and some discs, didn't look used, think they were fit to make a complete axle. Just in the corner of the garage now, I went with cossie rear calipers and a solid disc cause I needed a Machanical handbrake, and there good, handbrake is abit naff.
    I think cossie 4x4 rear callipers will take the vented disk, whether you need rear vents it is a different story.
    Aug 2015
    Leeds
    767
    Interesting to know, next time it's in bits I'll have alook got a few vented discs lying round
