is the lower timing pulley on the crank the same as a pinto
i think they are but would like to make sure
if anyone can help would be great
mk1 escort cossie
a pinto one hasnt got the lugs on it for the tdc pickup
do you mean the toothed one, or the alt/powersteering pulley with lugs?
I'm using a cossie crank with a single pinto alternator pulley. I had to have a spacer machined (just an extra cossie pulley bolt washer) as the nose on the cossie crank is longer than a pinto one and protruded approx 10mm on the other side of the pinto pulley.The toothed timing belt pulley is a standard pinto one and that fits with no mods. I am using a SOHC head. HTH.
