Re: World cup x-member bushing dimensions
Sorry, nothing useful to add, but your P7B looks lovely.
No problem, I got the dimensions
Outer diameter: 47,80mm
Inner diameter: 7/17"
Inner tube length: 65,30mm
Outer tube length: 50,40mm
Where could I get just the bushing and the outer sleeve? I don't need the kit as this will be for 2.9 V6
The outer sleeve is just a tube....and the bushes are available ..e bay...or burton..peter lloyd rally ect...love the car..by the way...cheers mark
I got some from milton racing and i believe they are MK1 cortina leaf spring bushes. They then used a spot weld ground back slighlty to give a good interference fit. That was some years ago they are now readily available from most of the UK ford rally parts suppliers as mentioned try RACE or motorsport tools gr4 fabrications etc.
As said thats a cool car.
