grs2000.
pin 6 is spark o/p B (36 is A) as far as i can see ?
http://www.extraefi.co.uk/Drawings/4...ack_Wiring.JPG
and
http://www.extraefi.co.uk/Drawings/W...om_VR_Hall.JPG
ive not looked at the internal mods tho i see pin 6 is wired from spr 4
cam sensors are normaly used for sequential.(ms2?)
stablau.....
the map i had running in vid was an alpha n map. kindly supplied by a guy on the success storys part of ms forum. seemed v.good !
pm me your email for a copy
it would work for you too grs, just need to alter the config settings to your spark setup ? should you want to try alpha n.
