Page 10 of 19 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 LastLast
Results 361 to 400 of 724
Thread: 1977 Mk2 Zakspeed Escort. Rebuilding my pride and joy.
  1. #361
    Apr 2017
    Essex
    797
    102
    Found an original engine splash shield. I don't even remember seeing one on a car back in the day, just that they are mentioned in a couple of my original maintenance manuals. (Just for anyone new, this isn't a sump guard ) I don't need a sump guard for a road / track day car but a splash shield to help keep the engine clean, yes please.
    Think the guy getting rid of it didn't realise it had got flattened out and needed re shaping to make it fit, which is done by gently warming it up.
    I've made up thin metal plates to reinforce the mounting flange. These will be pop rivetted on. Also got to drill and fit captive nuts in the chassis rails. Pics to follow.
    Also been doing more seam sealing on the underside now it's back on the jig.
  2. The Following 2 Users Say Thank You to Zakspak For This Useful Post:
  3. #362
    Jan 2012
    Aberdeenshire
    417
    Garage time isn’t easy for some and like you it has been very limited. Glad to see are still at her and she is taking shape. You going to get her into paint this year
  4. #363
    Apr 2017
    Essex
    797
    102
    Paint is planned and booked for end of March / April. I don’t want to let that slip as the waiting list is long. It could go to paint now, but ideally I want all the drilling and pre fitting done. Last thing I want is to be taking a drill to it when it’s had a new coat of paint. Also if I decide on doing something different or make a mistake it’s no real issue to sort out pre paint. I’ve really only got the fuel/brake pipe clip mounts and fuel pump fitting to do as far as drilling/welding is concerned.
    The paint shop is doing all the body preparation, surface filling and final gapping before paint.
    All the running gear is prepared and sat in boxes ready for rebuilding. The plan being that once the cars off to paint I’ll build it all up, and it will be fitted at the paint shop so it will come back a rolling shell. That’s partly lead by the paint shop not liking finished shells being transported on skates, which suits me fine.
    It all sounds like a great plan, but let’s see
  5. #364
    May 2016
    Germany
    288
    63
    Fantastic work mate. It nicely come together step by step! I found so much non drilled holes after the paint job...
    Very nice attention to detail. Love it
  6. #365
    Apr 2017
    Essex
    797
    102
    Thanks skmotorsport,
    I’m sure like you, despite my best efforts I’ll still find something that needs drilling. I don’t think realistically I’ll get round to dry fitting my wiring loom, that’s going to require extra fixing holes I think.
    I’ll just try to get as much done as possible, especially in the difficult areas like underneath
  7. The Following User Says Thank You to Zakspak For This Useful Post:
  8. #366
    Apr 2017
    Essex
    797
    102
    Update time over the next couple of evenings.
    There's been a fair bit of test fitting and some clean and prep of parts.
    The engine splash shied came up well, but may not be used as the fit is tricky with the anti dive kit
    The replacement radiator arrived, and test fitted all ok
    Bump stops cleaned and painted. They came up really well.
  9. #367
    Apr 2017
    Essex
    797
    102
    Made up these covers for the gearbox mount brackets. I don't want to use captive nuts and without the covers I can see these becoming dirt traps. Used the mesh left over from the speaker louver replacement covered in tissue fibreglass & resin.
    Expansion tank mounting
  10. #368
    Jan 2012
    Aberdeenshire
    417
    She is coming on and it’s good to trial fit everything before paint as it’s a nightmare afterwards as there is always something that needs a bit of fettling to get it fitted
    Looking forward to the updates and keep them coming
  11. #369
    Apr 2017
    Essex
    797
    102
    Thanks Donnie, id you get the pictures of your car back up on the site ?
  12. #370
    Apr 2017
    Essex
    797
    102
    Side splash panels have these dimples pressed inwards where the lower trim securing bracket fits.
    I'd fitted the brackets over the dimples, and knocked the dimples outward. Bit of a bodge, so had to re do this.
  13. #371
    Apr 2017
    Essex
    797
    102
    Bare metaled the boot recesses
    Re made the dash pod fixing brackets
    This is all stuff I realised I wasn't happy with as I approach paint time
  14. The Following User Says Thank You to Zakspak For This Useful Post:
  15. #372
    Apr 2017
    Essex
    797
    102
    Fuel system
    Got a bit out of sync here, so to recap, I'm running fuel (copper) and break lines under the floor like the Sierra's using Sierra plastic clips which screw to brackets welded to the floor.
    Fuel line runs marked with tape (yellow fuel, red break), and the initially formed fixing brackets.
    Making up the brackets with M5 captive nuts. They're numbered because a couple are slightly different to fit the floor shape.
    Brackets fitted
    Test fit of clips and pipe
    Attachment 87036
    At the back to take the pipes around the axel arch, 2x "S" type brackets to take M4 chimney nuts and a different type of plastic pipe clip. This reduces the radius of bend to the pipes.
    Fuel and break pipes fitted
    (Needed an extra bracket at the bottom of the bulkhead)
    Speedo cable clips fitted and checked
  16. The Following User Says Thank You to Zakspak For This Useful Post:
  17. #373
    Jan 2012
    Aberdeenshire
    417
    Looking nice and tidy, well worth all the work :-)
  18. The Following User Says Thank You to donnie For This Useful Post:
  19. #374
    Sep 2020
    south wales valleys
    62
    183
    i thought you would ave painted underneath before fitting pipework, or are u doing a dry build first.
  20. #375
    Apr 2017
    Essex
    797
    102
    It's fitting and dry fitting, you don't want to be welding and painted car, and this is not a standard fuel line fit for a Mk2 Escort.
  21. #376
    Apr 2017
    Essex
    797
    102
    This is the picture that failed above, test fitting the clips
  22. #377
    Apr 2017
    Essex
    797
    102
    Box of parts for the fuel system. Steel mesh pipe is for outside and the nylon for the return line inside. The hard lines are separated at both ends by the flexible pipe to reduce vibration between the sections and give some play, without the bulk of the flexible tube running under the floor
    Fuel pump set up, ally plate fitted under the boot floor on rubber anti vibration bobbings. Power supply will run in the groove of the boot floor and exit via the lucus type grommet and connect to the pump. This saves making extra holes in the boot floor and the original hole lines up perfectly
  23. #378
    Jul 2018
    Aberdeenshire
    127
    29
    That's really neat, like that
    www.instagram.com/thehighclassescort/
  24. The Following User Says Thank You to Baron von Teuchter For This Useful Post:
  25. #379
    3,242
    Only word of caution is the pipe mount bracket spacing! If the pipes were fixed directly to the panels I think the spacing is fine but having them 'floating' at 600mm? centres will allow vibration and flex to work harden them and then crack. If it was me i'd double up the brackets / halve the spacing. Mine are in-car and use rubber lined P clips @ 300mm ctrs.
  26. #380
    Sep 2020
    south wales valleys
    62
    183
    im with you Katana, on this one also.
  27. #381
    Apr 2017
    Essex
    797
    102
    Concerns noted, this issue of work hardening copper pipe crops up every time someone uses it, but I've never seen anyone post pictures or describe personal experience of a failure. I don't remember seeing a vibration induced failure of copper pipe in other applications either. Like the dissimilar metal debate, yes it's a real issue but has to be taken in context.
    I've not thrown this together either, there's a recommended support spacing (can't remember off the top of my head) which I've followed, and it considerably less than 600mm (8 clips x 600mm spacing =4.8 meters, how long is an escort floor ?) Also these clips aren't floating, they are bowed, as you tighten the screw to secure the clip it flattens and clamps the pipes (the Ford clip department really thought these through at design), The 2 at the back clamp by a hooked catch. If it springs a leak, I'll be back here to let everyone know what an idiotic idea it was to use copper fuel lines.
  28. #382
    Apr 2017
    Essex
    797
    102
    Fuel tank outlet, modified to male AN-6 (Credit to Donnie as this was inspired by his outlet modification)
    Standard fitting with the steel weld in AN-6 fitting
    Threaded section removed and a small recess ground inside so the AN bung seats in the fitting
    Leaving a nice little channel for the weld
    Clamped up to hold it tight and square for welding
    Welded, dressed off and flats made for tightening the fitting in the tank
    The return. Inlet
    Removed the original straight steel tube and replaced with 8mm copper to take the nylon meshed return pipe
    Soldering this is a little tricky and needs some time and preparation because of how the steel and copper react to the heating. Most important is to tin both and keep every thing very clean.
    Fitting a bend as measuring makes me believe the flexible pipe will not have space to form onto a straight inlet without the possibility of kinking
    This is attached after so the correct angle is set to align when the sender unit is fitted in the tank
  29. #383
    Jul 2018
    Aberdeenshire
    127
    29
    I'm no metallurgist but i've experienced plenty of bi-metal corrosion on land rovers where aluminium panels meet steel. Door frames and skins rot like absolute buggery
    Oddly, never seen it on an escort with aluminium wheel arches and steel wings.
  30. #384
    3,242
    Slight misunderstanding - the 'free floating' referred to the length of pipe between the mount clips - fixed rigid at either end, the middle suffers the greatest vibration.
    I've seen a few copper brake lines fracture through poor support so i'm maybe a bit paranoid - HP fuel line leak, under the car, near a hot exhaust - draw ones own conclusions !
  31. #385
    Jan 2012
    Aberdeenshire
    417
    She’s taking shape nicely and you just keep at it. Looking onward to seeing her in paint
  32. #386
    Apr 2017
    Essex
    797
    102
    You’re not wrong re the landies, despite my best efforts to protect the new door panels I fitted to my series 3 after about a year, tiny tell tale signs of corrosion were spotted, but it does take years for it to really come apart. That maybe because as aluminium corrodes it forms a coating ( aluminium oxide I think) which isolates the aluminium under it and significantly slows the process.
    This is why you can leave an aircraft sat our side for years and whilst it wouldn’t be airworthy, it wont collapse in on itself like an Escort or Capri would.
    And the ally arches on steel wings thing just goes to show it has to be in context. Thinking about it, probably because the landy doors are just painted but the arches are sealed with filler, paint and under seal, so if moisture is removed from the reaction the reaction stops. Anyway back to the build.....
  33. #387
    Apr 2017
    Essex
    797
    102
    Thanks Donnie, I was there yesterday dropping some parts off and seeing the progress
    These updates are running several weeks behind. I’ll try and catch up as time allows
  34. #388
    Apr 2017
    Essex
    797
    102
  35. The Following User Says Thank You to Zakspak For This Useful Post:
  36. #389
    Apr 2017
    Essex
    797
    102
    Made up front break lines. I'm using copper nickel brake pipe.
    Strips of masking tape to mark pipe routing
  37. #390
    Apr 2017
    Essex
    797
    102
    Fuel return fixings. Chassis rail tapped to M5.
  38. #391
    Apr 2017
    Essex
    797
    102
    Another job, the bonnet spring lock/release. The stem isn't long enough to comfortably screw into the bonnet and catch under the locking spring. So I got an 80mm bolt, cut the original stem off about 10mm above the cone, put a chamfer on both, set them up square, welded and dressed. Wasn't sure this would work, so didn't take pictures of the process.
    Painting along with the fuel tank outlet
    Both put together.
    Now found a place to get the release spring assembly plated.
  39. #392
    Apr 2017
    Essex
    797
    102
    That fuel outlet with the 90* bend.
    Whist I don't think there would have been a problem with the flexible pipe passing between the chassis rail and leaf spring,
    (You can also see the An-6 bulkhead return fitting)
    by changing the 90 to a 120 I can bring the flexible pipe comfortably to the chassis rail and use a P clip fixed to the chassis using a rivnut and M5 screw
    And it works
  40. #393
    Apr 2017
    Essex
    797
    102
    Fuel regulator fitted.
    Been some head scratching here to get everything to fit, regulator has to be accessible, a crank/rocker cover oil catch tank and the washer bottle being on the outside of the wing. I like everything accessible for future maintenance and repair.
    Wondered if a fuel rail mounted regulator would have been a better option ?
  41. #394
    Apr 2017
    Essex
    797
    102
    Expansion tank fitting
  42. #395
    3,242
    Nice piece of work but I query the outlet pipe size - the bit with the chamfer in the tank? Seems to replicate original bore at 1/4" / 6mm? If so, there is a chance of getting pump cavitation - all the pump feeds are -8 so nearly 0.45" bore, that outlet is equal to a -4! With HP pump feeds - bigger is better.
  43. #396
    Apr 2017
    Essex
    797
    102
    Katana, it’s the original feed tube, and I wondered if it might be worth either removing it or maybe drilling holes in it top to bottom, with enough static fuel sat in the pre pump fuel line and filter to provide sufficient reservoir to the pump. Now you’ve made me think I’ve got to do something to reduce the restriction it could cause just in case.
    I didn’t go with a big supply pipe as I’m running a standard Zetec, but maybe I should have as it wouldn’t have had any negatives.
  44. #397
    Jan 2012
    Aberdeenshire
    417
    You have put a lot of work into it and it’s taking shape nicely. Looking forward to seeing her in paint, good thing about the dry fit is that once it’s back from paint she will take shape in no time
    Like the mod to the bonnet pin
  45. #398
    3,242
    That's the thing with efi pumps - they are running effectively flat out, all the time with a good proportion of what's sucked out, then returned to the tank. Drilling holes in the standpipe won't achieve much as the pipe through the 'bung' is still chocked down to 1/4". Personally I'd drill it out to as close to the -8 bore as you can achieve,
  46. The Following User Says Thank You to katana For This Useful Post:
  47. #399
    Apr 2017
    Essex
    797
    102
    [QUOTE=donnie;3747725]You have put a lot of work into it and it’s taking shape nicely. Looking forward to seeing her in paint, good thing about the dry fit is that once it’s back from paint she will take shape in no time
    That's what I'm hoping Donnie, and I don't want to be drilling holes in a freshly painted car. Although there's still lots to do so I don't think I'll be on the road this year
  48. #400
    Apr 2017
    Essex
    797
    102
    Other stuff I've done is to finish of shaping and smoothing the arch duct outlets and shaping the arches to match. There's been quite a lot of work on the fibreglass. Various brackets fitting and checking
    Finished off the sealer and re did areas I wasn't happy with making it smoother.
    Then one last roll over before going back on the skate
