Page 15 of 19 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 LastLast
Results 561 to 600 of 724
Thread: 1977 Mk2 Zakspeed Escort. Rebuilding my pride and joy.
  1. #561
    Apr 2017
    Essex
    801
    102
    ECU temperature sensor.
    The Omex ECU sensor (standard Ford Zetec part) has an M12x1.5 thread so I tapped this in the top. Same measuring and drilling process.
    The ECU sensor can use PTFE tape (recommend by OMEX) it also has an O ring seal, and due to it's size I didn't use an adapter, going straight into the casting.
    Fitted to the Head.
    Here you can see the 2 rear sensor tappings, (plugged) and the crank breather pipe I made up fitted.
  2. #562
    Apr 2017
    Essex
    801
    102
    The support bracket I made up for the front of the water rail, I just wasn't happy with. It was far too clunky.
    On the right, support No1 and on the left "take 2" which I'm much happier with. It's about half the weight of the first support and is a lot less clunky & home made.
  3. #563
    Apr 2017
    Essex
    801
    102
    Just a note, the people at Raceline were really helpful with discussing options and methods for modifying the water rail for the sensors.
  4. #564
    3,248
    You've documented pretty much the same 'stumbles' I found using the Raceline rail. When I asked about the front support, Raceline hadn't heard of that problem ! so I came up with a similar strap arrangement - not pretty but functional LOL! I too liked / preferred the RL rail and yes the limited drillings was a problem also - I put the ECU sensor into the thermostat housing as a solution. The thing that I couldn't live with (in an escort at least) was once the RL rail was fitted - and it has to be before the head / engine is in the car - I couldn't fit the ex. manifold, there just wasn't the space! I had to lift the head just to fit the manifold which I found un-acceptable so I swapped to a RetroFord rail just for the ease of access etc. I wise i'd kept the Ford crankcase vent but that went in the bin years before the engine got built and any subsequent vent arrangement has leaked - bugger!
  5. #565
    Apr 2017
    Essex
    801
    102
    Raceline now supply a front support bracket but I thought it was expensive for what it is.
    I thought about putting the ECU sensor in the thermostat housing or the front hose, but the instructions said it has to be pre thermostat. Another reason for putting it at the back was it’s picking up the water temperature as close to the block outlet as possible, in case that makes any difference.
    Re the exhaust, you mentioned it before. I found during dry fitting the engine I couldn’t get the exhaust manifold on (Retro Ford 4-2-1) I believe the same as yours, and that was without a water rail fitted. Could you get yours on and off with the RF water rail fitted ? Mine was the geometry of the down pipes dropping between the block, bulkhead and the chassis rails when trying to feed it in from above. I dropped the cross member to increase the clearance to fit the manifold. It works but I hope I don’t have to go removing the manifold when it’s all done as it will be a right pain in the arse once all the front running gear is connected to the cross member.
    Plan for engine fitting is to lift it into place from underneath with the gearbox and exhaust manifold fitted. Engine is on my trolley now, sitting in the cross member with the gearbox fitted whilst I get on with other jobs in the engine bay whilst there’s plenty of room.
    Donnie said a similar thing about the crank breather, I looked at other options but figured Ford spent some time and money working out the best option so I stuck with it. I’ve removed the spring and ball stopper from the valve so it’s just venting and will plumb it into a catch can.
    More updates to follow
  6. #566
    3,248
    No - I could not fit the ex. mani with engine in bay and cyl. head / RL rail fitted! I had to lift the head off (with the RL rail obvs) then get the ex mani (same as yours) in the hole and hold it back out of the way whilst replacing the head. This is when I think I screwed up the cam timing so when I tried to start it . . . . . . it clattered / snapped two valves requiring a new head (cheaper than getting new valves + machinework!) Silly mistake but checked the timing multiple times with new head LOL!
  7. The Following User Says Thank You to katana For This Useful Post:
  8. #567
    Tyre Kicker Willi's Avatar
    Germany
    I checked the shoes and they are all the same, so swapping shoes around will give the same result.
    I'd be interested to see what you have fitted for a comparison. I'm going to look into this a bit more just in case there is a problem with the shoes I've got, although they came from Burtons and were in a sealed box, still worth checking.
    I marked the lining material on the shoes with some chalk on this photos of my Escorts left rear brake. Note how the shoes are actually the same, but the lining material is located in different positions.
  9. #568
    Germany
    If I spot it right on a photo you previously posted it looks that your brake shoes are the same as mine.
  10. #569
    Apr 2017
    Essex
    801
    102
    [QUOTE=Willi;3779749]If I spot it right on a photo you previously posted it looks that your brake shoes are the same as mine.
    Willi, thanks so much for taking the time to follow this up and post your pictures. Yes clearly the shoes are different, so I’ve put them on wrong. I’ll have to swap that around. I can see what I’ve done now matching the leading shoes one side and the trailing shoes the other not noticing the lining position.
    That’s a real “gotcha”.
  11. #570
    Apr 2022
    Israel
    24
    [QUOTE=Zakspak;3779934]
    Quote Originally Posted by Willi View Post
    Zakpak, do you put spacers on the rear axle? Or leave original? My dad put rear spacers
  12. #571
    Apr 2017
    Essex
    801
    102
    Tom you asked me this before!
    No I don’t need spacers, the wheels fit nicely in the arches 8” front, 9” rear
    I may use a thin spacer 2-3mm to ensure the wheel nuts/stud combination I’m using has a few extra threads to tighten against. But I don’t need them for wheel alignment.
  13. #572
    Germany
    I am glad I could help.
  14. #573
    Apr 2017
    Essex
    801
    102
    With the engine together, before fitting I've got a 10 micron pre injector filter. Not wanting to drill any holes in the wings I've had to come up with a fitting idea and going onto the cross member seemed to be best. The bracket is all bench made.
    With the filter bracket done, dry fitting to make up the hoses.
    Still catching up on the updates
  15. #574
    Apr 2017
    Essex
    801
    102
    Time to get the engine off the stand with the cross member fitted, and down on to the skate to fit the gear box.
    Front of the car will be lifted and the engine slid in from underneath then lifted into place.
  16. #575
    Apr 2017
    Essex
    801
    102
    Fitting Type 9 gear box to Zetech E Black Top
    Going to go through this in a bit of detail in case anyone is doing the same and isn't sure.
    Fitting the pinto clutch fork to the aluminium bell housing
    The pivot pin is stepped and simply taps in to the drilled hole. Just got to decide the correct side depending on Left or Right hand drive.
    Pivot pin with rubber anti rattle sleeve fitted
    Pinto clutch fork for RH drive
  17. #576
    Apr 2017
    Essex
    801
    102
    Clutch spigot bearing.
    Rear face, with the slightly wider rim and stamping
    Forward face, thinner rim, no stamping
    Liberally greased, and gently tapped into the crank shaft so its flush.
  18. #577
    Apr 2017
    Essex
    801
    102
    Don't forget the sandwich plate, aligned on the dowels.
    Down on the RH side there's a "jigsaw" type join on the plate, that needs to sit flush before fitting the bell housing/gearbox otherwise the plate flexes and twists.
    Lightened fly wheel on. A socket and bar on the front crank bolt stops the crank turning while torqueing the fly wheel bolts (Don't forget to fit the crank sensor bracket first)
    Spare input shaft used to align the pinto clutch. (I was given this by the guy who fitted the ATB)
  19. #578
    Apr 2017
    Essex
    801
    102
    The bell housing to gear box bolts use spring washers that without a flat washer chew into the aluminium. I got some washers that dropped into the machined recess and drilled them out to fit the bolts.
    With the bell housing fitted to the gear box it's time to fit to the engine
  20. #579
    Apr 2017
    Essex
    801
    102
    Thrust bearing fitted.
    This was a bit tricky on my own. I used blocks of wood and plastic spacers to align the gear box to the engine. When it's aligned correctly it more or less slips straight on. This took some time to achieve, a second pair of hands would have been helpful.
    Done
  21. The Following User Says Thank You to Zakspak For This Useful Post:
  22. #580
    Apr 2017
    Essex
    801
    102
    Clutch cable bracket.
    I've replaced the hex bolt with a better looking cap head.
    Starter motor fitted.
    Gear box support. I had to file a slot on the front to allow clearance for a webbing on the gear box.
    I've also drilled 4 small holes in the bottom of the mount to allow any water that could get in there to drain out
  23. #581
    Apr 2017
    Essex
    801
    102
    The rear breaks, I've removed and re fitted the shoes in the correct orientation as pointed out by Willi.
  24. #582
    Apr 2017
    Essex
    801
    102
  25. #583
    Apr 2017
    Essex
    801
    102
    Pedal box fitted
    Reservoir fixing plate and break line plates fitted along with Speedo cable with new grommet
    View up under the dash
    That's it for now. Up to date. Almost ready to fit the engine and gear box.
  26. #584
    Aug 2012
    Scotland
    128
    29
    Coming along nicely. Thanks for taking the time to post up pics and keeping us up to date with your progress.
  27. #585
    Apr 2017
    Essex
    801
    102
    Had a few jobs to do on the back end. The poly bush pads that sit around the leaf spring I thought were in contact on the sides so not sitting flat. So I've taken out the lower one each side and cut 3mm off the side wall. Once refitted and tightened there's now a 1mm gap between them.
    Also cut 10mm off the U bolts so there's 3-5 threads out of the nuts.
    Removed the front spring hanger bolt, trimmed that down and torqued it up. I hadn't done it before as wasn't sure if I'd be refitting the skate.
    Finally going around putting paint on the end of bolts.
    I'm thinking about removing the spring pads completely, but for now they can stay. If I take them out there's a few things to consider, I'll have to insert another 1/2" lowering block to keep the ride height, and make up a saddle to locate the spring in the base plate. I've some other thoughts for this. That can all wait for another time.
  28. #586
    Apr 2017
    Essex
    801
    102
    Battery cable.
    I'm using tinned Ocean Flex 35mm2 cable. Worked out on loading and volt drop plus contingency. It has hard wearing chemical resistant insulation, is corrosion resistant, and very flexible. This is run in a flexible conduit for extra protection (belt and braces).
    I'm running this through the chassis rail.
    The conduit is a close fit to the cable. It took me 4 hours to feed the 4m of cable through the conduit.
    Routing under the rear seat, through a floor bung. Plastic bung will be cut to take the cable and act like a grommet.
    Out through the front jack point, there'll be a grommet here. The jacking holes aren't needed as the standard jack doesn't work with the X-pack kit. I've always used a scissor jack, ( I never liked the Ford jack, X-pack or not)
    I reinforced the jacking points on the chassis rails when I was preparing them for fitting.
    This is a dry run for trimming. It'll be coming out to have the battery and starter motor terminals fitted.
  29. The Following 2 Users Say Thank You to Zakspak For This Useful Post:
  30. #587
    Apr 2017
    Essex
    801
    102
    The big news today. Now sitting on rear wheels !
    Seeing it sat on some wheels is a big deal, I hadn't anticipated the grin factor it would give.
    Even the Mrs came to the garage to see.
    As per a previous post I'm going to lift the front, pivoting the car on the rear wheels, to make clearance to push the engine/gearbox in under the front before lifting it into place. That could be happening tomorrow, watch this space.
    Anyone following this thread will note these aren't the wheels for this car. These are for a Capri I've been looking for and still not found. I missed out on one during the first lock down. So they are spare for now and have good tyres.
    I believe these maybe the JPS Capri wheels from their part number.
  31. The Following User Says Thank You to Zakspak For This Useful Post:
  32. #588
    Apr 2017
    Essex
    801
    102
    5 days later. The engine and gear box has been in and out 3 times.
    Day one, preparing and setting up.
    Lifting point through the ARB bracket fixing
    Front lifted and engine being pushed into place
    First lift was very cautious as I'm on my own. Removed the oil cap to save lifting any more. Looks like it will clear but it's an illusion.
    In the hole, and the front lowered back onto the axel stands
  33. #589
    Apr 2017
    Essex
    801
    102
    Exhaust fitted, ready to lift the engine into place.
    The engine is offset to the right to allow the exhaust to clear the chassis rail.
  34. #590
    Apr 2017
    Essex
    801
    102
    Problems.
    I got it wrong with the ECU temperature sensor position.
    This completely through off the alignment of the gearbox mount and crossmember
    Doesn't look much
    The other issue is the battery cable, its just too close to the exhaust if I stick with my original plan
    Battery cable will exit out the other side of the chassis rail and loop under to the starter motor.
    The temperature sensor I decided to make a cut out for it in the flange, I've marked the cut on the flange
    The other option would be to re position it to the side of the water rail, but as the paint is now damaged on the flange the cut out seems like the best option.
    So engine out. Cut out made with a tank cutter, and a coat of zinc primer
    Paint and lacquer
    Ready for refitting.
  35. #591
    Apr 2017
    Essex
    801
    102
    Fitting No2. The cut out didn't work. It was so close that the sensor still contacted the flange as it was being lifted in damaging the paint. Once it was in position its was ok but if it ever failed I'd have to drop the engine to replace it. That's no good.
    Out with the engine again. Time to re tap the water rail moving the sensor to the side.
    This isn't the best position, as the sensor needs to be spaced out because it's too long.
    Ideally I should have put both sensors in the underside
    I'll use an aluminium plug in the top hole.
  36. #592
    Apr 2017
    Essex
    801
    102
    With the temp sensor moved, it's in.
    With taking it in and out, the engine mounts became uneven in the cross member and caused the whole lot to skew off to the left pushing the rear end of the gearbox to the right, so the mounts had to be Knocked back into position to allow the mount to line up.
    It's probably going to have to drop down again to do odd bits like loom installation, but I don't think I'll have to fully remove it, we'll see. I'll also check the 4* drive train line described when I did the dry fit, I've used temporary plain nuts which will be replaced with nylocks.
    Battery cable also moved to exit on the outside of the chassis rail and that seems to work ok, just need to think about the best and tidiest way to secure it, probably a couple of P-clips.
  37. The Following User Says Thank You to Zakspak For This Useful Post:
  38. #593
    Apr 2022
    Israel
    24
    Attachment 88660
    Attachment 88661
    Attachment 88662
    Attachment 88663
    Attachment 88664
    Attachment 88665
    Hi friend, is there any progress on the renovation? I would be happy to chat with you about some questions in my email and I will send you the email address details
  39. #594
    Apr 2017
    Essex
    801
    102
    Hi Tom, yes making progress but not had time to update and it’s little bits around the engine bay and loom adjustments which are time consuming and don’t show much progress. I’m hoping to update this week time and work allowing
    Please feel free to ask questions. There’s a wealth of knowledge and experience on this site. I’d suggest asking in the “Info request “ area unless it’s something specific to my build then ask here.. As per your previous request for email details I don’t have time to answer questions here and on email, and again there’s plenty of people here with more knowledge than me.
    Why don’t you post some pictures and info on your dad’s car ? So far all you’ve posted is one or 2 pics of its parked on a drive way.
  40. #595
    Apr 2022
    Israel
    24
    Yes, I will talk to my father with a screen, I will upload photos from our project in about a week and a half, the car will be towed to the garage to build new pipes, and a few more things, the problem is that the photos are published around the web, I understand
  41. #596
    Apr 2022
    Israel
    24
    And a question I wanted to ask you, did you install front suspensions, what shock absorbers did you install? And what shock absorbers did you use, are they custom or normal and what springs do you have? thanks tom
  42. #597
    Apr 2017
    Essex
    801
    102
    Please have a look back through the thread, everything I've done and used is recorded here, if not I've not done it.
    GAZ inserts in RS struts, -2" fast road Coil springs, can't remember the loading, I bought them 30 years ago.
  43. #598
    Apr 2017
    Essex
    801
    102
    ECU temp sensor
    Dowty seal, DIY threaded spacer, Washer
    Fitted, and M12 plug fitted in the top hole
  44. #599
    Apr 2017
    Essex
    801
    102
    Batter cable fixing to front chassis rail
    P-clips, chassis rail tapped to M5 and an M5 Rivnut used in the strengthener
  45. #600
    Apr 2017
    Essex
    801
    102
    Final adjustments to the loom, placing loom supports (P-clips), Fitting relay sockets. All the holes get the usual zinc paint, primer then 2k paint for protection, all put on with a fine brush, I've used a mix of rivnuts and M5 screws and nylock nuts depending on access .
    Loom is now removed ready for wrapping.
  46. The Following 2 Users Say Thank You to Zakspak For This Useful Post:
