Results 1 to 9 of 9
Thread: 2.8 into 1959 100e
    May 2007
    newcastle
    161
    2.8 into 1959 100e
    hi all
    does anyone have in depth pics and or plans of how to fab a tunnel and bulkhead
    bulkhead and floor cut and 2.8 wit 5speed box in place...just not got a clue where to start wit the welder like
    Jul 2007
    Macclesfield
    97
    Re: 2.8 into 1959 100e
    IMO the best thing to do is find an existing one like from an old crapi. just cut it out and make it fit! The benefits being you get all the little captive nuts and stiffener mouldings already there and I think it looks better than a folded up piece of tin. Its also a hell of a lot easier than folding up the said piece of tin. Just a quick q though, why the 2.8 when there are loads of 2.9's about for beer money?
    May 2007
    newcastle
    161
    cheers fld never thought of that...hmmm.
    i was thinking of buying a 2.9 cosworth granny that way i would have ecu loom the lot and now with that i could cut out the bulkhead and tunnel
    does the 5 speed box from the 2.8 go on the 2.9 with a flywheel change...should do i think as long as its six bolt crank.
    COSWORTH GRANNY NEEDED HERE CHEAPISH
    World Champion Decade Plus User popuptoaster's Avatar
    Jan 2003
    Brentwood, Essex
    9,508
    yes all the 2.8 bits will bolt onto the back of the cossie motor, but the gearbox will be way over its design limits, it may be ok in a small light car without much grip if your not to vicious with it though.
    Jan 2003
    Brentwood, Essex
    9,508
    er? i have no idea how that happened?
    Jul 2007
    Macclesfield
    97
    Pop-ups right, the 2.8 box is weedy! Most poeple seem to opt for the mt70 or T5 although there has been some effort into using a skyline box on the cos 24v. Have a rifle round the ford power forum if you need some pointers on boxes. The granny will have a tunnel for an autobox best to get one from whatever car you get the box from that way you'll get a good fit.
    May 2007
    newcastle
    161
    aye never though about the box like as 200 bhp should be pumping through it and my right foot is very vicious i will av`e a look at what box is in there thou i suspect an old 2.8 granny box.
    i take it the engine mounts should just bolt back onto the four hiles on the cozzy block
    Jan 2003
    Brentwood, Essex
    9,508
    yeah standard cologne mounts will fit the 24v, its heavier though so if the rubbers are soggy it may sit a bit low. the MT75 box comes in V6 rwd form in germany so ebay.de might turn one up, otherwise you need to get a hybrid built from the front half of a 4x4 box and the rear of a 2wd as the bellhousing isnt removable.
    its worth noting the 24v is wider at the top as well so if space is tight in your bay you may have problems, in my cortina for example the heater box gets in the way on the passenger side while a 12v will fit straight in.
    as it happens i just noticed this ad for a box on this very site, i know barry as well, he's a good lad, will be able to help with lots of 24v stuff
    http://www.turbosport.co.uk/showthread.php?t=129006
    May 2007
    newcastle
    161
    rubbers are new
    and there is pleanty of room but look at this i just missed on ebay http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=330222764067
    just my ruddy luck like
Similar Threads
  1. 100e Project
    By donald in forum Your Cars
    Last Post: 05-02-2008, 11:58
  2. Ford 100e
    By s1pickup in forum Wants
    Last Post: 08-10-2007, 17:26
  3. 100e Prices
    By oliver in forum General Car Banter
    Last Post: 31-01-2007, 01:05
  4. 100E wheels
    By Stevenoz in forum Old School Ford
    Last Post: 07-09-2006, 18:48
  5. 1959 Supercharged Morris Mini Minor
    By ClassicFords in forum Cars For Sale.
    Last Post: 11-04-2006, 15:18
