Page 5 of 15 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 LastLast
Results 161 to 200 of 581
Thread: Dubai Mk1 Duratec
  1. #161
    Mar 2004
    Harlow, Essex
    14,285
    318
    Re: Dubai Mk1 Duratec
    As long as the box cant be seen when looking across the chassis rails its fine,
  2. #162
    Sep 2007
    The Netherlands
    Looking great! Is the MX-5 box a straight fit to the Ford Duratec engine?
  3. #163
    Aug 2006
    Christchurch, New Zealand
    463
    Awesome work you've done there mate, I'm going to enjoy watching this build Do you ever fly down to Christchurch at all?
  4. #164
    Dec 2007
    Dubai
    1,678
    29
    Thanks Gary, that is what I thought
    Yup, straight bolt up, no mods required. The 2005 onwards MX5 (NC Model) has Duratec engines in it.
    Well I used to go a lot, as I fly for a Middle East airline that goes there daily, but they have changed the aircraft to a type I don't fly, so not at the moment. However will be down in November for holidays
    www.gulfpetrolheads.com
  5. #165
    Remember the camper......? Decade Plus User
    mk1matt's Avatar
    essex
    7,616
    70
    Cool cheers for the info
  6. #166
    Dec 2007
    Dubai
    1,678
    29
    Whipped the top of the gearchange house off
    Was told by Dave from RetroFord that a RX7 Short Shiter like this will fit
    so bought one on eBay for £32 delivered
    Started up making a gearbox crossmember, quite fun as all the angles are off-cock due to the 10 degree angle of the box in the chassis
    Used up a set of spare Watts link bushes as the rubber mounts
    Then recycled a set of rear leaf hangars for the chassis mounts, nice thick steel they are, no doubt they are collectors items and this is heresy of some description, but they are no use to me
    Tidied up the butchered tunnel brace, welded a couple of bits of thick plate on the inside of the tunnel to spread the load
    The bottom of the mount is just about 5 mm below the chassis rail, so all tucks up pretty well
    Finally made up a couple of alloy plates to fill the gap between the rear inner arches and the rest of the boot firewall, just needs a bit of seam sealant to finish it off
  7. #167
    Mar 2004
    Harlow, Essex
    14,285
    318
    On the rear 1/4 sealers.. make sure you have few mm#s of gap between the plate and the 1/4 ... if its touching you'll see it when you polish the outside as it will push through.
  8. #168
    Mar 2006
    In the garage getting cold
    1,448
    31
    Doing a great job and some very impressive fabrication work
  9. #169
    Dec 2007
    Dubai
    1,678
    29
    just as well I have a few mm already in places then, but I will shave a bit more off before I permanently rivet them in. I guess being aluminium they should cause less damage as well
    Thanks, considering I started this without having done any metal work, its amazing how quickly you learn, it gets better with every new thing I do, that is for sure. Still no where near the pro's though, but I guess that is to be expected
  10. #170
    Mar 2004
    Harlow, Essex
    14,285
    318
    I always use ally aswell..but when i was young and foolish... only a few years ago mind, i butted it tight..took me fecking ages too.. and after about 4 polishes and countless bums leaning on that area ..i had a line show up ... so now.. solid seam everywhere before paint ..then after paint, silicone those to the 1/4 so its a rubber cushion
  11. #171
    Oct 2008
    MANCHESTER UK
    Quote Originally Posted by Retromotorsport View Post
    use mirror silicone as it has no acidity and will not eat into the steel.
    There is a special silicone for sticking mirrors onto things if you were wondering
  12. #172
    Pit Crew Decade Plus User GAZZAMK2's Avatar
    Mar 2006
    Exiled in Lancashire
    949
    Top work there fella, real quality.
    Gotta say too, great advice from the Gary there, spot on.
    One to keep an eye on this....
  13. #173
    Spanner Monkey Med's Avatar
    Aug 2005
    Kuala Lumpur, Malaysia, Malaysia
    317
    u're damn good in fabricating those works...! RESPECT!!!
    is there many oldfords' in doobye..? i dun think so...
    anyway, GOOD LUCK mate..!!!
    +-+-+-+-+- http://med.fotopages.com -+-+-+-+-+
  14. #174
    Dec 2007
    Dubai
    1,678
    29
    Mirror, silicone, you learn something new every day, once again thanks to Gary for the save of the day.
    Med, couple more Escorts in Dubai, not common tho, but we are trying to build interest
  15. #175
    Oct 2008
    MANCHESTER UK
    Normal silicone is actually corrosive, it will eat into Alu and steel, especially if moisture is present. Mirror silicone was developed to stick mirrors to walls etc and not eat the reflective backing stuck onto the glass to make it mirror.
    Mirror silicone is actually less prone to silicone paintwork also...although I would never use it in a body shop and only apply it after the paint has hardened etc.
  16. #176
    Tyre Kicker R1.Andy's Avatar
    Aug 2009
    uk
    15
    excellent thread m8..and cracking job your doin..
  17. #177
    Feb 2009
    some where
    191
    excellent work mate keep it up it coming along nicely
  18. #178
    Bodger hansgti's Avatar
    Dec 2008
    Bangkok
    166
    Some hard graft going on there , the end result should be a winner
    What goes on at the Dubai aerodrome?
  19. #179
    Dec 2007
    Dubai
    1,678
    29
    well they are still building terminal 4, albeit a bit more slowly
    Otherwise not much. Looking forward to flying the new A380 soon, which will mean lots of BKK flights.
    Would love to come and see what you lads are up to over there as the Old School scene looks to be alive and kicking, with some interesting local solutions
  20. #180
    Bodger rvf-boy's Avatar
    Dec 2006
    plymouth
    74
    your doing a cracking job there you be up and running befor i finished welding,
    is there a reason you have put your wing rails on the wrong sides like easyer
    fitting of glass fiber wings ??? just thought i would ask
  21. #181
    Dec 2007
    Dubai
    1,678
    29
    First one to spot it or mention it, which surprised me, but yes, tried the rails on both ways and after a lot of head scratching decided that the GRP wings sat/hung much better with the rails the wrong way round. Also Rivnuts are hidden n the inside of the wheel arch.
  22. #182
    Dec 2007
    Dubai
    1,678
    29
    Well its been a busy couple of months and not got much done to Svetlana, however finally the stars aligned so that I managed to get 6 days off in a row from work and my mate Gareth finally got his pipe bending machine down to his new garage, so it was time to do a cage. Did a bit of research and happily plundered the MSA Blue Book and Custom Cages website to choose a design that works for me
    All the structural welding was done by Gareth, so I take no credit for that part of the cage construction, likewise he was the technical advisor, having done a few of these in the past
    First order of the day was to make some boxes out of 3mm plate, to sit the main hoop legs on
    The purpose of these was to allow the main hoop and front legs to be tacked together
    Once the main hoops were bent and tacked together we then knocked the boxes out and dropped the main hoop to weld the top joints that sit up against the roof. Once the top welds were done, we reinstalled the boxes, welded them in and attached the main hoop legs as well
    Wish I could weld as well as this with 2 hands, never mind one handed
    Gareth doing his welding duties
    Time then to link up the rear turrets to the cage and also a cross bar that will be used for the seat belts
    Decided it would be a good idea to link up the front turrets as well, so I put the tubes through the front bulkhead and chopped them longitudinally, then plated the half tube and welded them to the strut cups.
    Bit fiddly to do and I will still need to tidy up those side panels, as I have never been happy with them, but there should be plenty of strength in the old girl's front end now
    While Gareth had his welder out, we put a couple of gussets on the link boxes
    Put a wee gusset to tie the cage to the gearbox tunnel
    Fitted the seat bars on the LHS, as initially this will be the side
    I will set up the car for LHD use in this country. I plan to make the car ambidextrous, so that is is just a mater of undoing a few bolts and swapping a steering rack to change it from LHD to RHD, depending on what country I am in
    Fitted the door bars after that, bloody fiddly to get right
    One thing that made the whole exercise a lot easier was an £80 purchase from eBay in the form of a tube knotcher, made blood quick work out of the trimming and shaping of the tube ends
    Used up 3 hole saws to install the whole cage, but reckon it saved a shed load of time.
    Here is the largely finished cage, I trimmed the bottom of the dash so that we could get the cross bar as high up as possible to mount the steering column onto it.
    The obligatory test session
    So that was my week, bloody hard sweaty (36'C) work, took five, 9 hour days to get it all done. Big thanks to Gareth and Jason at a2b Garage & Motorsport here in Dubai
    In for another hiatus until the next edition as finally getting to do my conversion onto the A380 next month, so Svetlana will have to languish in the shed untouched for a month or so.
  23. #183
    Nov 2003
    Wirral UK
    6,740
    257
    Nice work there, cage looks good
    http://escort.accelerator.org
  24. #184
    May 2008
    Wales
    looks good seems you took it to the rite place
  25. The Following User Says Thank You to gareth For This Useful Post:
  26. #185
    Apr 2004
    Bangkok, Thailand, Thailand
    4,346
    479
    Nice work with the cage mate
  27. #186
    Moderator+ Decade Plus User
    dangerousdave's Avatar
    Oct 2002
    London
    15,132
    65
    Great work neil, well worth the weeks work it looks great and a must have been much cheaper doing it yourself
    Cant wait for the next update, not long til its in paint at this rate
  28. #187
    Nov 2008
    Adelaide, Australia
    1,331
    96
    Fan-blooming-tastic!
  29. #188
    Spanner Monkey Wessie's Avatar
    Aug 2006
    Guildford, Surrey
    35
    447
    19
    coming along nicely
  30. #189
    Dec 2007
    Dubai
    1,678
    29
    Thanks lad's really appreciate the comments. Dave it sure did save a bit of money to say the least, but more importantly like all things to do with this car, I learned a lot. Really made me understand what a lot of work is involved in putting a cage in and that it is defo not a career I am aspiring to
    Think I will keep it to once every 2 years or so
  31. #190
    Dec 2007
    omagh
    top class work great welding skills
  32. #191
    Tyre Kicker ExtraHot's Avatar
    Aug 2009
    Cape Town,South Africa
    19
    A1 cage dude
    perfect joins & welds
    OLD FORDS never die,they just get FASTER!!!
  33. #192
    Aug 2006
    463
    She's looking brilliant mate All the best with the conversion to the A380.
  34. #193
    Spanner Monkey qcadta's Avatar
    Jul 2007
    Invercargill, New Zealand
    258
    lookin good A380! the escort would pass as carry on baggage compared to that
  35. #194
    Dec 2007
    Dubai
    1,678
    29
    Well the A380 course is coming to an end, so a quick sneek out to the garage to do a few jobs. Firstly picked up a couple of kick/bulkhead panels from eBay for £20 each.
    Never was happy with the look of my old patch up sides, so thought I would do them again
    Lot happier with that now, here is the other side
    Then Christmas came early, one of my mates Jason who is racing in the local Saloon car series here donated a set of discs and calipers from his Civic Type R, after doing an upgrade to even bigger ones
    So one set of Brembo 295x28 discs...
    With the bells removed (actually these are another mate, Spencer's old discs, which already had the bell removed)
    Then after a bit of head scratching on offsets, I made up a quick and dirty, mock-up bell out of 2mm steel to try out positioning on the back of the Capri hub
    Still a bit of clearance on the TRE, I reckon I can get about another 5mm out of the gap, which should be just enough to make a 7mm flat bell. Don't know if a 7mm flat bell is thick enough for strength, the original Brembo one is 7mm but of course it is bell shaped so may be stronger. Dunno, any thoughts
    Here is the caliper (yes it is the wrong side for the arrow), looks pretty meaty
    Looks like the brackets at the back should not be too much of a hassle, never done this before so a bit of a voyage of discovery
    Fit nicely inside the wheels, think the caliper has to slide out a bit from the centre once mounted, but all looks like it will fit.
    Piccie of wheel just in case you were wondering what it was.
    So all in all looks like a very decent set of brakes, big thanks to Jason and Spencer for the donations to the cause
  36. #195
    Oct 2002
    London
    15,132
    65
    Nice brakes and nice wheels
    Flat bells are fine as far as i know, i have seen a couple around like it, and i think the ones my brother had made are flat too If you want more meat you could always go monster on them and have the disks fitting to the bells from the front, then you wouldnt need to take the hubs off to change the disks?
  37. #196
    Nov 2008
    Adelaide, Australia
    1,331
    96
    Your build has me drewling
    Great work mate....well done
  38. #197
    Pit Crew Decade Plus User merp0's Avatar
    Jun 2007
    Chester, Cheshire, United Kingdom
    1,284
    100
    Nice cage
  39. #198
    Pit Crew Hoogi's Avatar
    Jul 2008
    Lancashire
    1,590
    All looking
  40. #199
    Oct 2004
    get me on my beeper,beeper
    11,882
    aint seen this thread for a while bud,you are still doing some stunning work on this real credit to you buddy.i had flat bells on my wilwoods on my mk2 and im pretty sure the ap bells on the new brakes are flat as well so i cant see that being a problem m8.as said lovely work so far
  41. #200
    Mar 2004
    Harlow, Essex
    14,285
    318
    Does A2B want a fabricator ...
    You'll soon be polishing the paint on this, keep up the hours
Similar Threads
  1. Escort Mk1 Duratec 2,3l
    By Jeroen in forum Restorations and Projects
    Last Post: 14-10-2008, 09:19
  2. Replies: 17
    Last Post: 30-12-2007, 21:32
  3. Speed bump in Dubai + flying Gallardo
    By zoso11 in forum Movies
    Last Post: 09-11-2006, 17:44
  4. Dubai Anyone??
    By M11rf in forum Message Centre
    Last Post: 28-10-2005, 17:00
  5. Duratec into mk1
    By lookalike in forum The Technical Section
    Last Post: 27-09-2004, 18:47
