Lot's of little jobs, trying to get the bottom of the car finished to get it back on its wheels, to fit the engine and gearbox (when they arrive)
Put the radiator mounts in, couple of M12 bolt shanks cut and welded in
Radiator fits like a glove now
Just the side mounts to make now.
Filled in the bit around the turrets for the firewall and shelf, which I will probably do in alloy.
Cut off the spring hangars, decided to take off the side plates as well as one looked like it might have a bit of corrosion under the plate, sure enough...
Was a pretty easy fix, but glad I did it.
As I wasn't using my spring hangers, no need to skid them, well waste not want not, a couple of hanger skids, re-allocated to the link boxes.
Not sure if it is an approved modification, but it does put a bit more longitudinal strength into the link box and skids it, just in case I mount a kerb or summit similar
Purposefully left them open, so they don't collect grot and cause rust.
Finally got around to welding in the strut brace
Again pretty easy job
So gradually working through a list of little chores, will throw the axle on again next week and finalise the fitting of the watts link bars.
Only real thing to do underneath is to decide whether it is worth bracing the Watts towers (a la Gartrac), this car won't be doing rally's or jumps, so not sure it is needed
