Page 9 of 15 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 LastLast
Results 321 to 360 of 581
Thread: Dubai Mk1 Duratec
  1. #321
    Pole Position Decade Plus User M11rf's Avatar
    Apr 2004
    Bangkok, Thailand, Thailand
    4,346
    479
    Re: Dubai Mk1 Duratec
    You are up early this morning
  2. #322
    Dec 2007
    Dubai
    1,678
    29
    Got myself a set of Sabelt 6 point harnesses from Gulf Sport, at a very decent price.
    Question is, am I OK to use the existing seat belt mounts for the lap strap and will the rear seat mount bar be OK to wrap the crotch straps around?
    Looks like the rear roll cage bar will be OK for the shoulder straps
    FedEx brought me an early birthday present today in the form of a new Emerald K6 ECU.
    This is the latest iteration of the K3 which I had last time, but has some new features in the hardware (waiting to be activated by a software update)
    It has been radically redesigned and has the latest generation powerPC processor, waterproof case and connectors, revised 1-channel/2-channel PWM, unipolar and bipolar stepper motor control, onboard Barometric pressure sensor, USB, serial and CAN interface and data storage memory, 6 ignition and 6 injector drivers. Some features will not be available straight away, but will be added as the software is completed. This can be done remotely by adding files to the software.
    I got the flying lead loom and plug with the loom, as I was too cheap to spend £250-300 for a custom loom
    The loom plug has already got many of the sensors wired in, all it needed was to insert the Wideband sensor wire, ignition feed and injector feeds, then label everything up, quite easy to do
    I have a Techedge 2J1 wideband O2 sensor to integrate into the loom for active mapping
    The ECU software version and config for those interested
    Not sure whether to use a MAP sensor as well as the TPS built in atmospheric sensor and air sensor. I know nothing about MAP sensors so not sure if I need to bother.
    www.gulfpetrolheads.com
  3. #323
    May 2008
    Wales
    He wont keep it long enough to have to worry about stuff like that
  4. #324
    Spanner Monkey Darbo's Avatar
    Nov 2009
    Lancaster
    462
    idealy with the lap belt they should be attached vertically from the holes in the seat side
    this is to stop you hitting your head on the roof when upside down
    the crotch straps normally attach to a pair of eyes welded to the rear seat mounting bar
    i suppose you could wrap them round if needed
    more details required for the emerald setup
    dunno if im going the same route
    so the more details you supply the more ill be convinced lol
    keep it up
  5. #325
    Dec 2007
    Dubai
    1,678
    29
    Quote Originally Posted by gareth View Post
    Huh, you back in town yet, am off to Auckland in the morning, back Saturday
    And I should care.....
    Seriously though this is my second Emerald, I really like the product a lot, I just wish Karl would get a forum or support website sorted sometime this century!
    Won't stop me buying what I regard as by far and away the best bang for the buck, it's just unnecessary.
  6. #326
    May 2008
    Wales
    that was in reply to the bulkheads fittings for the wiring didnt see rest of the posts.
  7. #327
    Dec 2007
    Dubai
    1,678
    29
    Got the initial loom planned out, pretty easy when you get stuck in, here is my variation (click here to download the PDF)
    Feel free to comment if you see any obvious flaws
    Laid out and tried in the car to get the correct lengths, then a bit of heatshrink
    The rest of the wiring and plugs will be sorted out after painting, as I am using grommets and not bulkhead connectors
  8. #328
    Aug 2008
    Queensland,australia
    492
    Great stuff mate, thanks for the detailed progress. very helpful.
  9. #329
    Dec 2007
    Dubai
    1,678
    29
    OK, small update, it seems to be taking me for ever to get every job done
    First off after much measuring I got the biggest air filter I could fit, to support the horsepower target I am after (280ish)
    Bit tight, but with a bit of judicious bending of the mesh frame, it fits pretty good, only problem is the only way I will be able to remove the air filter is to also remove the throttle bodies, still happy with that as a compromise.
    Bought a 75mm flaring tool on eBay, does a great job, so 7 nice holes later
    Fitted my wings properly and did some work on the panel gaps, needed a fair bit of filler on the right hand side to get it all to fit properly (Smith & Deakin) Particularly at the top of the door
    Left hand side before, does not need as much work
    Cleaned up the doors, cut the insides out of them, as will be running fixed poly windows, kept the door opener. No real restoring required, just an hour or two of cleaning up the surface rust.
    Other door after cleaning and rust proofing
    Then with alloy panel to cover up
    Spent a bit of time today trying to work out were to fit the oil cooler, ended up this was the only place that I could make work.
    Only occludes the radiator a little
    Finally had a look at what hoses I need to pick up from Think Auto on Monday morning, when up in Heathrow for the day
  10. #330
    Pit Crew Decade Plus User raymondmarble's Avatar
    Sep 2005
    Dundee
    1,029
    116
    Looking fantastic! I keep forgetting this is a Mk1. Keep up the great work!
  11. #331
    Pit Crew Decade Plus User MK1_Oz's Avatar
    Nov 2008
    Adelaide, Australia
    1,331
    96
    How are you planning on mounting the polycarb side windows? Tossing up with using a 5 piece kit in my car but I will only do it if it can be mounted neatly and securely. Also, did you get the formed rear? Is it a direct copy of the glass one??
    Good to see your still at it........
    1970 Mk1 Escort Tarmac Rally Car
  12. #332
    Dec 2007
    Dubai
    1,678
    29
    I didn't use that much filler did I??
    The rear window is formed, according to the bloke who supplied me, they are all designed to be held in by the original seals, yet to try them. I picked up a couple of little alloy strips from Ralloy to support the door windows, as I have taken out the window lift mechanism
  13. #333
    Mechanic waynemk2's Avatar
    Dec 2005
    Wales
    774
    Hi
    Just read through your thread, good work keep it up. looking at your engine fittin pics reminds me of what i had to do when i fitted my motor.
  14. #334
    Nov 2008
    Adelaide, Australia
    1,331
    96
    Quote Originally Posted by dobuy View Post
    So you are planning on the poly sliding into the existing top and side channels but then held up there with this alloy strip underneath (pressumably rivetted into place)? You got one piece or two piece door poly?
    I am a little concerned about the poly becoming one big Rolf Harris wobble board and making a noise. Hopefully the front sliders may help to reduce that on the front windows but not sure how the rear side and back will go (if the back is formed as per the glass one then it should not be an issue).
    Do you have any idea of a completion date yet for your car?
  15. #335
    Dec 2007
    Dubai
    1,678
    29
    Yep, something like that
    November or December is the plan, just not sure which year tho'
  16. #336
    Nov 2008
    Adelaide, Australia
    1,331
    96
    :d
  17. #337
    Dec 2007
    Dubai
    1,678
    29
    Checked out how to fit the poly windows, as the car is primarily planned to be used on the track, I never see it using wind up windows again. So using the standard window channel on the top, I slid the poly window into place. I had thought about using some kind of cunning channel, but decided instead to bolt the windows through the inside of the door to the other side of the window channel. Will get a few pretty domed Allen bolts to tidy it up.
    Picked up some nice window strengthener fillets from eBay for the roll cage
    Bit of seam sealing, in anticipation of paint
    Bracket for the
    Rally Design front chin spoiler, unfortunately it was not meant to fit bubbles, so a bit of chopping and GRP filler
    Blended in OK now
    Made up some checker plates for the floor, thanks for the sheet Gareth!
    Bare metalled the doors
    and after several days of bare metalling, seam sealing, filling and cleaning the shell, finaaly got her to hi-build primer
    Funny how the flash shows up the little bits you missed
    Have to say the roll over jig is bloody handy for painting, hardest bit is getting all the tubes painted
    Morris showing me how to do the doors properly, think the kitchen stool will need a bit of TLC in the form of a Ford colour
    Not a bad effort at that
    So tomorrow it is stone-chip for the underneath, then maybe a lick of top coat on the stone-chip to seal it off
  18. #338
    Pit Crew Decade Plus User jpblue's Avatar
    Apr 2005
    Back in London again
    957
    18
    oooh Im getting excited, you must be buzzing.
    looking great, keep up the great work,
    cheers, Justin P
  19. #339
    Sep 2005
    Dundee
    1,029
    116
    Fantastic work mate! Keep the pics coming!
  20. #340
    Nov 2008
    Adelaide, Australia
    1,331
    96
    It's like a baby is coming.........we are the expectant Dads!!!!!!
  21. #341
    Dec 2007
    Dubai
    1,678
    29
    Thanks for the comments. Am really enjoying this part of the resto, but it is a lot of hard work trying to get all the little details of the bodywork right. Got the stone-chip done yesterday, will maybe get a chance to flick a coat of top coat over the stonechip today, then that is about all for a month or so between work and holidays.
  22. #342
    Dec 2007
    Dubai
    1,678
    29
    Did a bit of body work the next day blending the rear bubbles, anohter coat of primer. Then got the Sonechip done OK, left it out in the sun for a couple of hours and it was piping hot, so no problems with viscosity.
    Finally a lick over of topcoat underneath the seal the stonechip and make the dirt fall off easier.
    Decided to stonechip the bottom of the front panel, as like most of these, it is not particularly smooth and I was bu**ered if I was going to try and smooth it all out with filler.
    Think it looks OK and it is certainly practical.
    So that's it for about a month, off on hollies soon.
  23. #343
    Aug 2008
    492
    Hi Neil, just wondering if you have tried to fit the Raceline Dry Sump to the block yet? I have the Raceline Dry Sump the same as yours but when I try to fit it to the block it rocks on the top of the ARP studs. I will try to add a picture of what I mean. Even if the threads on the stud were trimmed down to try and get enough clearance it still wouldn't be enough as it would also mean taking some of the nut away as well. This would leave nothing gripping the stud. Just wondering if you had come acoss this problem as I don't have a clue what to do from here. I will email Raceline but they are very slow in replying to emails as this is something that is hard to discuss over the phone as the pictures clearly show the problem. Thanks.
  24. #344
    Pit Crew Decade Plus User turbo m's Avatar
    Sep 2006
    cambridge
    1,056
    Did the spoiler fit to the front pannel ok? as i have been thinking about one for my mk1.
  25. #345
    Dec 2007
    Dubai
    1,678
    29
    It didn't fit because of the bubbles on my GRP front wings. So took a fair bit of modding, but was easy to do. Should be fine on standard wings
  26. #346
    Sep 2006
    cambridge
    1,056
    Thanks for that wasn"t sure what quality the rally design fibre glass was..
  27. #347
    Dec 2007
    Dubai
    1,678
    29
    Quality wise, it was fine, just didn't fit with bubbles
  28. #348
    Sep 2010
    kedah, malaysia
    90
    nice car... love to see it when its done..
  29. #349
    Nov 2008
    Adelaide, Australia
    1,331
    96
    What colour is that you are using??? I have changed my mind on colour so so so many times!!! We are now thinking that the car was Vermillion Fire from the factory so either that colour or another shade of orange is probable!!
    Also, have you done anything to prevent the alloy door card from drumming??
  30. #350
    Dec 2007
    Dubai
    1,678
    29
    I went for Signal Orange, a standard Ford colour of the period, as used on Mexico's etc I think
  31. #351
    Mechanic terry's Avatar
    Jan 2004
    east mids
    933
    looks like your doing a good job ,keep it up
  32. #352
    Dec 2007
    Dubai
    1,678
    29
    returned from holidays a few days early to get some of the car painted, had a bit of a mare with the Hi-Build Primer struggling with the heat. It did not really lay on as wet as I would have liked in places, never mind, lots of sanding and time for top coat of the interior and engine bay
    Was an absolute pig getting an even colour round all the tubes and nooks and crannies, fairly happy with it, but never again
    Engine bay and front was easy by comparison
    Body should be much easier, at least for access, still lots of prep to do, but getting there. Got a 10 days of work ahead, sot no more 'til October
  33. #353
    Pit Crew Hoogi's Avatar
    Jul 2008
    Lancashire
    1,590
    Love that.............looks very smart in the new coat.
  34. #354
    Apr 2005
    957
    18
    Stunning, cant wait, quit the job and finish it for me would ya!!
    Cheers,
    JP
  35. #355
    Moderator+ Decade Plus User
    dangerousdave's Avatar
    Oct 2002
    London
    15,132
    65
    Looks lovey neil great work
    As for the thinners going off too quick are you just using std thinners or have you got some slow thinners to try to help you out?
  36. #356
    Dec 2007
    Dubai
    1,678
    29
    Not sure Dave, with hindsight I would probably not use hi-build again for the interior. But it all turned out OK and the top coat went on very nicely, few bits may need a lick over with a polishing mop to remove the odd bit of overspray and dust, but pretty happy with it. The outside of the car will be the proof of the pudding.
  37. #357
    Nov 2008
    Adelaide, Australia
    1,331
    96
    Is this single pack paint? Will you clear over the top? I have not got anywhere near the painting stage yet so am yet to start my research on paint types/processes.
  38. #358
    Dec 2007
    Dubai
    1,678
    29
    The paint is 2 Pack or 2K, which just means you have to mix the colour part with reactive thinners (or hardner) to get it to "go off".
    The paint I am using is Dupont, but all the big manufacturers, Glasurit, ICI, PPG etc do similar 2K paints.
    The colour coat is a high build coat, which gives it a bit more depth than one you are going to clear coat over. What this means is that the reactive part has a high solids content and looks quite viscous, but adds body to the colour part, when you mix it.
    I am not using a top clear coat, as I wanted something that would be easy to repair if I get any little knocks on the track and as I am using a standard old school Ford solid colour, clear coat was not required.
    If you are doing something similar, you would need
    Etch (Wash) Primer to cover bare metal
    Hi Build Filler primer to cover old paint and the etch
    2K Hi Solids top coat (2 coats, wet on wet, 40 mins between coats)
    Quantities depend on level of restoration, but if it is a full resto seriously consider the time and effort it will take and maybe get someone to paint it for you!
  39. #359
    Nov 2008
    Adelaide, Australia
    1,331
    96
    Thanks for that mate. 2K is the one that you need the respirator to apply (ie dangerous stuff)? Is that the one that also takes quite some time to cure so needs to be kept dust free for a few days??
    I want to paint myself if I can for 3 reasons;
    1. run out of cash
    2. learning a new skill
    3. can say I did 100% of the car build
    I know I will live to regret it though
  40. #360
    Dec 2007
    Dubai
    1,678
    29
    Yep, very much the same reasons why I wanted to paint mine. The hard bit is round all the nooks and crannies with a roll cage installed, without this it would have been a lot easier.
    2K is something to be careful with and is well documented as the stuff contains Iso-cyanates and really does your lungs in over time. However there are plenty of very effective cheap masks that have activated Carbon filters. The one I got cost £20 and I could not smell anything through it, made the mistake of taking it off when finished spraying and I could not believe the density of the fumes, so they do work. Note the main carbon filters actually wear out because of exposure to Oxygen, as well as getting clogged by paint dust, so have to be stored in a sealed bag.
    Have a look here to see some examples of what will work
    If you are only painting one car, I would argue you will be fine with a chemical fumes mask like mine, rather than an air fed mask. Also get the $5 polyester suits with a hood and wear plastic gloves, then you will be well protected.
  41. The Following User Says Thank You to dobuy For This Useful Post:
  1. Escort Mk1 Duratec 2,3l
    By Jeroen in forum Restorations and Projects
    Last Post: 14-10-2008, 09:19
  2. Replies: 17
    Last Post: 30-12-2007, 21:32
  3. Speed bump in Dubai + flying Gallardo
    By zoso11 in forum Movies
    Last Post: 09-11-2006, 17:44
  4. Dubai Anyone??
    By M11rf in forum Message Centre
    Last Post: 28-10-2005, 17:00
  5. Duratec into mk1
    By lookalike in forum The Technical Section
    Last Post: 27-09-2004, 18:47
