Pinto engine
Hi quick one can someone let me know if I can put efi set up onto a non efi engine or is it more complicated cheers
Re: Pinto engine
quick answer ..yes...but you would need all the wiring/management/distributer ect...and if you were using a non efi head you would have to make some room for the injectors...(bit of grinding)...or use an efi head...cheers mark
Re: Pinto engine
as above, grind a bit out the top of the inlet port and fit all the injection bits including dizzy
