Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 41 to 80 of 170
Thread: Which exhaust manifold for pinto
  1. #41
    Bodger grzelu's Avatar
    Sep 2010
    warsaw, poland
    101
    9
    Re: Which exhaust manifold for pinto
    Photos of the head and dyno sheet
    Attached Thumbnails Attached Thumbnails IMG_2580.JPG‎
    IMG_2586.JPG‎
    IMG_2585.JPG‎
    IMG_2408.JPG‎
  2. #42
    Mechanic hawk1903's Avatar
    Jun 2009
    istanbul
    956
    269
    Still confused !!!
    Although RL31 is one of the best profiles from Kent ( as it is ), I doubt it can create this much torque with the calculated/existing CR.
    On the other hand, as far as I know, RL 31 can work with up to 11.5:1 but the sweet point should be 11.0:1 for RL31. I am sure, friends here might have share their experiences with the well known RL31.
  3. #43
    25,110
    Quote Originally Posted by grzelu View Post
    . Bigger dyno I will try to add although this site allows only very small attachemnet sizes
    the site has an uploader function (tab near top of page just under the picture of the yellow escort) use that to put up pictures, resize them first to around 800x600 pixels then up load and copy/paste that link into your post, no more small pics then
  4. #44
    Sep 2010
    warsaw, poland
    101
    9
    Graham - Thank you. Link below:
    hawk1903 - the torque was confirmed on two dynos (one showed 210nM, the other 207nM). The only thing different was power but I believe more in the latest/smaller one (above).
    If you think that for this cam CR 11:1 is the optimal then I should skimm only 1mm more...wonder if that can significantly help with power though..? Btw - new 2.25" Ashley manifold is also here
  5. #45
    Jun 2009
    istanbul
    956
    269
    Well, 11:1 is what I wouls use if I was building an engine with RL31 due to our hot climate etc issues. However, RL31 may accept very little more CR as well, may be even up to 11,5:1
    Here at TS, there are friends very familar with RL31 and successfully used RL31 in their builds.
    If I remember correct, Graham build a very nice engine with RL31 but I am not sure about the capacity of that engine at this moment.
    Certainly it is a good cam out of the box but there can always be much better custom profiles which is designed by knowledgeable people..
  6. #46
    Jun 2009
    istanbul
    956
    269
  7. #47
    Jun 2009
    istanbul
    956
    269
    Regarding the target chamber volume, it is hard to say cut/skim 1mm and you will reach to xy cc. I normally skim bit by bit and keep measuring the chamber and modify the chamber shape if it is needed etc.
  8. #48
    Sep 2010
    warsaw, poland
    101
    9
    Quote Originally Posted by hawk1903 View Post
    thank you. I have to stay now with a ready / of the shelf cam as it is. Any other opinions from "TS friends" familiar with RL31 ? what CR you have/recommend for this cam? Unfortunately I have to decide by morning - last moment to do the skimming (then workshops vacation, and then the rally). M.
  9. #49
    Jun 2009
    istanbul
    956
    269
    In my opinion, for a reliable Pinto for these range of road/rally profiles, 11:1 CR is a safe bet with a good pump fuel. I think you will have a good result with 11:1 once the cam timing and your fueling fine tuned on a rolling road.
  10. The Following User Says Thank You to hawk1903 For This Useful Post:
  11. #50
    Spanner Monkey redhf's Avatar
    Jan 2006
    uk derbyshire
    58
    479
    164
    Rl31 is very popular on here search the site for rl31 loads of builds by some good people
  12. #51
    Mar 2012
    2,118
    RL31 (BP300 for Piper customers) is indeed a very nice profile. It's always working in a good prepared engine. It was still in the days of trial and error I already found this as a good torque / power cam. This cam is perfect for a very fast road / track day car.
    You can never go wrong, over the top with this cam and will give high Bhp numbers as well. RL31, A8 (Piper) and HT1e all tested in the same engine where within 4 Bhp from each other. Engine made 189 (RL31) and 193 (HT1e) Bhp. The RPM range for HT1e was higher and the engine was able to run higher in RPM but not making extra power. The RL31 did stopped sooner.
  13. The Following User Says Thank You to Dyno For This Useful Post:
  14. #52
    Sep 2010
    warsaw, poland
    101
    9
    Onyd - thank you , it's very valuable info. What compression ratio you recommend for and engine with such cam ?
  15. #53
    Sep 2010
    warsaw, poland
    101
    9
    Guys, one more question. How much valve advance For this cam I should set (as an entry stage, before adjusting on pulley) ? I think we had something around 16 degrees in past....but I'm not sure and different garage is working on this now. Ps. Sorry for vocabulary / not professional wording
  16. #54
    Jun 2009
    istanbul
    956
    269
    Hi again,
    Regarding the camshaft timing ( via the adjustable cam vernier ), Kentcams catalog says, inlet valve must be open 3.33 mm @ TDC or if you are using the full lift method, Kentcams says 106 degree @ Full lift.
    These figures are from the catalog. Once you decide about the static CR and build your engine and time the camshaft with either of the above figures than fine tuning of " camshaft timing " ( towards advance or retard ) best be done on the dyno along the fuel mixture ( at least to be on the safe side at wide open throttle under the load )
    Note: As a general rule, regarding the camshaft timing, instead of 3.33@TDC you may start with inlet valve very slightly more open than exhaust valve @ TDC and start from here and fine tune/time on the dyno.
    Due to your selected CR ( during the build ), you may end up, may be with a more advanced cam timing, for example 3.50 mm @ TDC during the dyno/rolling road session. But I believe, RL31 will be good around 3.15-3.30 mm @ TDC cam timing.
    There may be other replies from TS members and they might have end up with different cam timing figure during their builds. Then, the main problem is very much related to unreliable cam manufacturers and the difficulty of getting the Pinto valve geometry correct in my opinion. At this moment, things get complicated on this particular engine.
  17. #55
    25,110
    i would time the cam in as i do most 1 degree advanced ie. full lift 105 degrees after TDC, my reasoning is, unless you know for a fact the cam will work better timed some other way its best to time it as per the manufacturers specs, i similpy go 1 degree advanced to allow for belt stretch.
    RL31 timed at 105 was what gave 200 bhp on the 2.2 i built dazzle
  18. #56
    Mar 2012
    2,118
    I use 11/1 CR
  19. #57
    25,110
    I use 11/1 CR
    being greedy i used a bit more, BUT depending on fuel quality you have that may not be possible
  20. The Following User Says Thank You to Graham For This Useful Post:
  21. #58
    Sep 2010
    warsaw, poland
    101
    9
    Cool Re: Which exhaust manifold for pinto
    thanks everyone for valuable comments. The head has been machined. After workshops vacation we will put it back together and go to dyno.
  22. #59
    Sep 2010
    warsaw, poland
    101
    9
    ok so all the calculations and skimming was done (heads height is now 91,6cm), car was put back on dyno (on wheels). Except for signifacantly different sound and little bit smoother acceleration in higher revs (but worse on lower), there is very small change in performance.... only 7Hp gained and no change in torque. Dyno chart attached. It seems very odd taking into accounbt that CR was rised from 9.68 to 11.21. Compression has been measured and rised from app. 9 to 11. What do you think ?
    My impression is that we can't get anything more from this engine (unit) or maybe I'm simply tired with no proper results.
    BTW - I also made a check on Carbs. They are ok and the current setup is:
    Weber 45 DCOE 152G
    choke tubes 38mm
    main jets 145 (played with 150 and 155 but mixture was to reach)
    air jets 180 (changed to larger, 200 or near due to fuel flooding during dyno)
    pumps 45
    emulsion tubes F16
    Idles 55f9
  23. #60
    Mar 2012
    2,118
    Sorry I've got not time to read whole topic but did you made a change in camshaft?
    What where the changes, more as raising the compression ratio ?
  24. #61
    4,887
    Was it 140-145 bhp at the wheels or at the crankshaft?
    In my experience F16 tubes in a newer 45DCOE carb is no good.
    A 145 main jet is consistent with 150 something bhp.
  25. #62
    Mar 2012
    2,118
    Why is a 145 main jet in consistent with +/- 150 Bhp ? I had a Golf 2 ltr 16V in Rally-Cross a few years ago. Made 200 Bhp and a lot of torque. Almost standard engine with perfect balanced cams. Running 45 DCOE, 36 mm chokes, F16 emulsion tubes and 145 main jet.
  26. #63
    Sep 2010
    warsaw, poland
    101
    9
    Click image for larger version Name:	IMG_5016.JPG Views:	249 Size:	92.8 KB ID:	82027Hi Onyd, no the camshaft is the same (RL31).
    We have changed the compression ratio and exhaust manifold (to Ashley) and adjusted flows in the head.
    The valves are the same (inlet 45mm, exhaust 38mm) and carbs as well. Dyno chart below - with previous and current output.
  27. #64
    Jun 2015
    Australia
    292
    Hi grzelu powers at the wheels good results what type of head are you using who ported it cheers mario.
  28. #65
    Mar 2012
    2,118
    7 Bhp at the wheels extra from only a manifold change (or head work). You should be happy. Please note, you always come to a point where finding extra power is a lot more difficult as when the engine is still on 110 Bhp and you want 120. That's easy.
    As I always say, raising the compression ratio from 9 tot 10 does make a noticeable difference. Raising from 10 to 11 makes a lot less extra power. Usual little over 10,5 / 1 it all drops dead for a normal rally camshaft.
    Slight drop at low RPM can come from exhaust and / or flow work. As can be the extra power on top.
  29. #66
    25,110
    given that we are talking power at the wheels, it looks like a decent power gain to me, not only have you got more but it hangs on to it much better, thats a much more user friendly power curve, ok you have lost a bit low down, but in a competition car if your ever using full throttle down at around 2500rpm, then your in the wrong gear!
  30. #67
    Dec 2014
    Mk
    Nearly 20 years ago now i brought a Mk2 RS 2000 from Rally & Competition Equipment , it said 180 hp Pinto on 48's .... well got it home had a tinker then popped it on the dyno at work that i operated. It was 124hp flywheel !!!!
    The head was removed and skimmed to get 10.5.1 valve heights done and another inlet manifold .... it was running a GP 1 cam and 44 inlet & 38 exhaust valves and 36mm chokes and 40 mm trumpets.
    In the end i got 136 at the wheels 165 flywheel and 149 ft it drove like a injected motor very smooth and grunty.
    So it only takes a few things not quite right or miss matched or " to big " to get a poor result and driving like a pig ...
  31. #68
    2,656
    267
    Over 20yrs ago my car went on the rollers.
    It was running 48's what was said to be slightly better than a grp1 cam a big valve head and 93.5mm pistons on a cossie crank an rods with cast pistons with about 10.8.1 cr. It had a 3pce manifold, not sure who it was made by though....
    It started off with the operator saying it wasnt running well and putting out about 125bhp@ the wheels. He asked me if I had any other plugs I could put in it while he changed messed about with jets, I said I only had some standard ones. He said ok, give them a go.
    It went from that to 160bhp @ wheels. He said he'd never seen a set of plugs and some jetting make another 35bhp.
    I remember it being really crisp an clean but only ever revved to 7k then stopped dead. I dont know how much torque it put out.
  32. #69
    Mar 2012
    2,118
    I always say, it's very easy to loose 20 Bhp by doing things wrong than gaining and other 5 Bhp on an already correct build end setup engine.
    Most people get stuck somewhere between 160 and and 175 Bhp. I've never seen any engine making 185 Bhp or more without a pro build head from company's like Vulcan CNC-heads etc..
  33. The Following User Says Thank You to Dyno For This Useful Post:
  34. #70
    Sep 2010
    warsaw, poland
    101
    9
    thanks for all the comments. On one hand I should be happy with results but on the other I'm way below results that others achieve.
    OK, maybe 7hp gain isn't bad after changing the exhaust and CR but where to look for significant change? My problem is towards current performance after all mods made to the engine from the beginning (not lat only).
    Onyd - you say that most people get stuck somewhere between 160-175....well, I got stuck on 145-150.
    I also remember Graham building engines around 200Hp...Ok, he is genius but I was aiming at 180 with this set up and more with different carbs, cam etc.
    Please advise where to look....or maybe I have to switch to an 16v modern engine and convince local scrutineers to treat it as replacement for BDG. Otherwise I can't compete in FIA3 class where my colleagues cars have 200Hp + (on wheels)
  35. #71
    Mar 2012
    2,118
    OK, this was 150 Bhp flywheel power, not engine power. For een RL31 it is rater low. But it's all in the head. Second, none of the other colleagues have 2 ltr Pinto's with 200 Bhp at the wheels. This can only be done with 16V modern engines like BDA, Warrior, etc...
    If you want a 190 Bhp Pinto engine, very simple, you order a Stage 4 cylinderhead from Vulcan (or other pro head), fit Piper A8 or HT1e camshaft, get yourself a set of 45 mm DCOE and 38 mm chokes, put a decent ignition on it (like Bastek), Ashley 4-2-1 Big-bore and you got it. You need a strong bottom end and valve pocket in your cast pistons.
    Even poor setup these heads still make 180 Bhp+ at the flywheel. Believe me, it'a ll in the head. I had 2 engines in less than 3 days one after the other on my dyno. Complete same stuff, even sharing the same exhaust. One made approx 187 Bp, the other barely 165 bhp. Only the head work was not the same. The 165 Bhp was also build by a so called pro engine builder but I believe this guy must have been drunk.
  36. #72
    Sep 2010
    warsaw, poland
    101
    9
    OK, this was 150 Bhp flywheel power, not engine power. For een RL31 it is rater low...
    Do you refer to my engine or the ones you had in the past?
    Also thanks for all other suggestions - I know its all in the head and it sees that to many "pro builders" were working on mine.
    regards
    M
  37. #73
    25,110
    at the moment we are all guessing, but you cam, carbs, compression and exhaust should all support 180bhp, so either they dyno reads very low or the head doesnt actually flow well at all, most likely the issue is the head. i assume it is a 2.0 carb (not injection) casting? do you have any pictures looking down the inlet ports? does the cam give the valve lift its supposed to?
    it would be expensive but if you send me the head i could flow test it, then we would have some idea as to whether its any good or not
  38. The Following User Says Thank You to Graham For This Useful Post:
  39. #74
    Mar 2012
    2,118
    Approx 25 year ago I've build several Capri engine, all round big valve heads bought in UK. One I had back on my dyno a few years ago for a camshaft swop. It made +/- 145 Bhp with RL31 but was setup with 44 IDF. You may expect little more with 45 DCOE.
    The same cam went into a rally engine I had in at the same time (I sold the cam second hand). This engine made 187 Bhp, Vulcan head and Weber DCOE 36 mm chokes.
    Believe me, it's the head that sets the max power, not the cam. This same rally engine made little over 190 Bhp with HT1e and 189 Bhp with Piper A8. And this result was also confirmed on a other dyno (Superflow).
  40. #75
    Mar 2012
    2,118
    RL31 and BP134 compare
    Attached Thumbnails Attached Thumbnails BP134 and RL31 kopie.jpeg‎
  41. #76
    Mar 2012
    2,118
    Please note, this power issue is not only related to Pinto's, it the same with all kind of engine. My friend got a flow bench and does work a lot with it and ofter testing a head he always makes a power quote by estimating. He is always very close
    I see 2Ltr VW T1 engine coming in with almost standard heads and making 130 - 140 Bhp and then you got "fully build" 2,3 Ltr engine making 125 Bhp (and not a few). Just to compare.
  42. #77
    Sep 2010
    warsaw, poland
    101
    9
    Ok so the head is the issue almost for sure. The cam is right. Maybe the chokes little to big (38mm) but shouldn't affect the output that much. Also the torgue is very good so it's the power that doesn't follow.
    Graham - my head was originally injected version from sierra.
    I will also PM you in regards to your suggestion.
    Others - do you know how much a Vulcan heads cost? I have a spare engine and think weather not to build a new engine and use current one as spare / back up. On the other hand I'm considering putting a newer affordable 16v engine but must be ford and as close to BD as possible (or at least not have and structural / modern advantages over BD). Was thinking of YB without turbo but they miss torgue. Zetec seems cheap and structurally 'worse' then BD so maybe local ASN would allow it. What engines your regulations favor for old escorts (as replacement) ?
  43. #78
    25,110
    yb without turbo is very expensive to great real power from, most dont make much more than a much cheaper pinto can
  44. #79
    Mar 2012
    2,118
    38 mm wil indeed not "choke" the max power. Can have negative effect on torque.
    There is nothing like "cheap power". Specially not if it has to be old school Ford and close to BDA. Once you want to go over 200 Bhp, let say 240, even a 16 valve engine will be expensive. A stroked, over-bored Pinto does make nice Power and Torque but again, not cheap.
  45. #80
    The Duratec Mazda chain drive engine is another one to consider. A decent head as std that requires little modification if any to get over 200bhp. No free lunch though as you'll need management and bodies, rod and pistons, cams, ex manifold and much more including belhousing engine mounts and so on.
