Results 1 to 2 of 2
Thread: tunnel for a type 9
    Nov 2006
    Co.Cork Ireland
    72
    tunnel for a type 9
    got a rs bellhousing with starter mounts on both sides but the tunnel looks like it needs a good belt of a hammer to get it to fit. will i be better off to fit a larger tunnel from burtons, rally design etc. is a larger tunnel needed anyway to fit a zetec so i can get the right angle for the engine
    thanks for your help
    World Champion Decade Plus User Pitstop's Avatar
    Apr 2003
    Essex
    66
    4,809
    Re: tunnel for a type 9
    RS alloy ones are okay. I think you only need to do a bit of bashing if using a T9 with the cast (original) bellhousing. You'll need to remove/jack out the original g/box mounting points though.
