Re: Rear Gearbox seal !!
its an easy job, remove the prop, prise old seal out and gently tap new on in place, refit prop and top up the gearbox oil
As thought but its always good to have a second opinion,top man !!!! Many thanks, is this a common fault do you know ? do you know of any other possibilities ? with this oil leak,place etc !!
