Results 1 to 15 of 15
Thread: Sierra T5 gearbox overhaul
    Jan 2016
    Hull
    246
    Need to do a rebuild on my Sierra T5 box, who in the UK can supply a full overhaul kit ie bearings/ seals/ shims / baulk rings and poss 4th gear synchro hub ( got a problem selecting 4th when cold ) there are some basic kits from the likes of Burton, the Gearbox man nothing in stock only option I've found is from the US. So any help would be appreciated.
    Sep 2006
    chesterfield derbyshire
    2,162
    Re: Sierra T5 gearbox overhaul
    Try sending honkywhitetrash a message. He has parts I think.
    Mar 2008
    west bromwich
    1,861
    G.e.a.r.s in southport , Bernie , at cts
    Jan 2016
    Hull
    246
    Just a bit of info neither GEARS or CTS will supply parts as all their stock is used for their own builds.
    Pit Crew Decade Plus User nickmk11's Avatar
    Sep 2004
    uk kent
    1,143
    Give these a shout you may even get 5th gear watch a few of his videos
    http://www.5speeds.com/cart/index.ph...&product_id=52
    https://www.youtube.com/watch?v=piCMtiE2XEE&t=1144s
    MOBILE REMAPPING KENT
    Jan 2016
    Hull
    246
    Thanks for the replies guys, will let you know when I get the parts sorted and who from. Cheers.
    Jan 2008
    Up the garage
    2,775
    218
    Are you going to cut the rear bearing off to get the box apart or do you have a decent 5th gear puller? Difficult job even with the proper tools!
    Jan 2016
    Hull
    246
    Would appear to the best to cut the bearing to save destroying 5th gear when you pull them
    Jan 2008
    Up the garage
    2,775
    218
    I had a proper puller made that gets 5th gear off without breaking it - I didn't want to be cutting the rear bearing shell in case the bearing was OK as fitting a new bearing almost certainly means re-shimming the main-shaft. It's not a problem if doing a complete overhaul though.
    It was a bit of an oversight on Borg-Warner's/Cosworth's part.
    Jan 2016
    Hull
    246
    The main issue I have is selection of 4th gear, it's just solid when cold but does get better once warmed up. But certainly not right. Apart from that the box is ok. Thought while I'm in there May aswell do an overhall because the milage on the box or history is unknown.
    Jan 2008
    Up the garage
    2,775
    218
    Could be expensive if you need a replacement main drive gear and synchroniser assembly! Are you using original ATF oil spec'd by Ford?
    Could be block bars - last box I did had broken block bar ends on 4th gear side.
    Will be a good chance to check end-float while box is apart.
    What BHP you running?
    Jan 2016
    Hull
    246
    Oil that was in the box looked like ATF, it's only at 280 bhp so nothing ridiculous. But don't know how it's been treated in its previous life. Now fitted in a mk1 cortina so it's not an easy task to remove. ..That's life!
    Jan 2008
    Up the garage
    2,775
    218
    OK, keep us posted.
    Jan 2016
    Hull
    246
    Click image for larger version Name:	image.jpeg Views:	67 Size:	304.1 KB ID:	82004Click image for larger version Name:	image.jpeg Views:	66 Size:	318.8 KB ID:	82005Got round to pulling the box apart, found that the 4th gear blocker bars had ground themselfs into 4th gear synchro ring! Got a overhaul kit coming from America next week
    Nov 2004
    Sweden
    1,167
    I have similar shit issues going into second, very hard when cold (especially downshifting).
    I haven't had a T5 apart, can you check synchros by just popping off the lid of the gearbox?
    I am running close to 300 whp and over 400 Nm so really above the T5 limits long term but still would like to figure out what the issues are before I decide what to do.
    Gustaf
