Results 1 to 10 of 10
Thread: BOA vs BOB cam Exchange issue
    Aug 2006
    CzechRepublic/Praha(Prag)
    Shit BOA vs BOB cam Exchange issue
    Hi All
    I am a little lost now so therefore screaming in the world "HEEEELP MEEE"
    I just exchanged my cams BOA 2 BOB but no good result happened - probably some error by me.
    So i was curious if you would not know what is wrong.
    It was simple exchange BOA cams out and BOB cams in same order ->
    BUT here i have already doubts - i was not able recognize the difference between exhaust and intake cam - are they same?
    left and right side is different by code FN1501 and FN1502.
    now the engine runs not fine - it shakes like crazy and no power at all - just the opposite - less power and at idle it goes offline.
    when i spin the engine twice - the set mark where good 1 to 2 and 3 to 4 was pointing.
    I feel like it is a little wrong or i should really use the BOB timing wheels - BUT when i had them in hand they looks like the BOA ones.
    I was trying to reach Tony (MadOldBugger) but ford power is down and i lost his mail somewhere - anybody have his mail ?
    Or any advice for me?
    World Champion Decade Plus User popuptoaster's Avatar
    Jan 2003
    Brentwood, Essex
    9,508
    Re: BOA vs BOB cam Exchange issue
    fordpower has a temporary forum at http://fordpowerorguk.slarti.myfreeforum.org/ i think the issue though is that you need to use the BOB washers as well as the cams, best check with em on fordpower though as i havent done mine yet.
    Jul 2007
    Macclesfield
    97
    Yup, deffo need the bob washers. Your cam timing is out!
    Aug 2006
    Quote Originally Posted by FLD View Post
    OK guys - will follow your advice.
    THX
    Sep 2006
    Derry N Ireland
    did you get it sorted and what was it as i am going to do the same
    Aug 2006
    shaking issue was badly connected ignition cables due to coil pack mounted 180degre wrong.
    timing was a little out - with BOB timing plated and TDC gauge i was able to set it correctly.
    but still no big power - i believe now i ned to MAP the ECU but i am still not shure.
    bought a new set of HEGOs and will try to exchange.
    new injectors are prepared.
    in your case do make tension on the chain.
    park the engine in correct possition - TDC and 1-2 and 3-4 marks pointing on each other.
    BUT there can be an issue in older chain(longer) - in my case.
    Aug 2006
    done done done
    this shit was just and death cable on left injector side !!! otherwise it was fine - just me silly boy rebuilded whole engine before the main failure was found... so an little celebration and...
    ... the Kraken engine is living again... electrical mess issue solved so just an short Superchip Punk installation and GOGOGO
    Tubed
    http://www.youtube.com/watch?v=ZNfZHVmRqCIYouTube- Ford Granada cosworth 24V 2door Custom RS - www.oldfords.cz - SuperChip installation and testing.
    Newsed = M$ ready
    http://news.oldfords.cz/content/ford...on-and-testing
    M$hit not ready !!! use Firefox or Chromoidor...
    http://www.oldfords.cz/en/obivanclan...on-and-testing
    Aug 2006
    hi all
    some of you know my story regarding the cam exchange issue.
    the fault was in the loom(injectors controll cable KO) and the rest was in bad timing disks received with the BOB cams.
    sollution is to get the best engine loom you can get - better get new one but... i know... there is no new one.
    and the rest was in bad timing disks - they where from an old engine and they had a small gap - but small gap in engine timing means a lot.
    also an old chain means a lot trouble, same with old chain wheels and that small sh!t called chain tensioner.
    so i had a good BOA engine and good BOB cams so i put them together and added also the fuel presure regulator with Vectra injectors...
    so you can have a look now at the result....
    its a small spin after a lot of time of work but i am pretty happy with the result.
    :ph34r2:
    Jan 2003
    Brentwood, Essex
    9,508
    Hehehee, nice one.
    Aug 2006
    ok - it was fun just the tires are gone so quickly...
    and i do not know why... :-)
    inside cam...
