MK2 Escort ignition barrel to steering column bracket
I have what I think is a MK2 Escort ignition barrel that clamps onto the steering column for which I'm missing the bracket that clamps it on.
Looks like this one that I found on here which is also missing the bracket.
Does any have one for sale?
I tried what I think was a MK1 Escort one and it doesn't fit.. is smaller diameter.
Re: MK2 Escort ignition barrel to steering column bracket
There is no bracket - there are ears are welded to the steering column, short bolts pass through and screw into switch casting.
