Help wanted
I'm in the middle of building my yb and the plug is broke of the Idle speed sensor that goes into the throttle body so I need to get a new one but I'm trying to find out about anti lag when I'm changing the it I'm thinking I might as well go for an anti lag one but what else is required to do this the engine runs a T4 turbo rs 500 inlet and throttle body thanks
Re: Help wanted
Anti lag vavle has a top hat on the bottom of it , it depends what ecu you run ? Can be done on l8 (mild version msd in Blackpool can do it and launch control
P8 can run it on pectel board , and pectel t6 which is a stand alone unit, just need software to run it , and a switch to put it on, as you don't want to run it all the time because of the heat build up It melts everything lol
