Results 1 to 10 of 10
Thread: Anyone got an injector cleaner?
    FOSSIE's Avatar
    Oct 2004
    NEWCASTLE
    1,591
    Does anyone have, or have access to an injector cleaner - and fancies earning a few beer tokens? Injectors are Bosch greens if that makes any difference....
    Thanks in advance!
    Part of the furniture Decade Plus User Tone's Avatar
    Jan 2003
    sarf essex
    8,656
    Re: Anyone got an injector cleaner?
    buy a cheap ultrasonic jewllery cleaner about £15 works a treat i'm told
    tones right, the injector cleaner does it ultra sonically ,so in theroy a jewelry cleaner should clean the injectors, you just wont be able to do a comparision between injectors or meassure actual flow rates. incidentally cleaning injectors usually REDUCES the amount of fuel they flow and the spray pattern actaully makes very little if any difference to performance
    9,204
    any idea why
    and what are these jewelry cleaners / where from ?
    its because when injectors are getting dirty they dont shut off the fuel as quickly as when new
    9,204
    i see, so they wont actually flow more in total, but the open cycle is effectivly increased.
    Clint's Avatar
    Jul 2001
    932,284
    The machine I use tests the spray pattern and flow, not sure how you do that with a £15 ultrasonic cleaner !
    Jan 2003
    sarf essex
    8,656
    its a cheap cleaner !!! i've just bought 6 brand new green giants from the states that are already matched, you pay your money and take your chances,
    if he can't get a proper tester/wants a cheaper alternative I SUGGESTED A CHEAP IDEA !!! he says cleaner not spray pattern tester
    Thanks in advance
    4,889
    Do not agree with this Graham.
    If you have really dirty injectors then that dirt is on the little filter inside the injector blocking the flow.
    I have cleaned alot of injectors, the only ones that really needed it were the ones in a car that ran out of petrol or ones that were lying around for a while in a garage ...
    When I clean injectors I put them in a ultrasonic bath, then reverse flush them, then put them in an ultrasonic bath again and finally test them for a correct spraypattern.
    Obviously this is alot of work and sometimes its better to just buy new ones.
    FOSSIE's Avatar
    Oct 2004
    NEWCASTLE
    1,591
    Interesting stuff chaps... Clint cleaned mine in the end - and although i have no real way of telling whether it made any difference - it was really just peace of mind for me as I found quite a lot of crap in the fuel filters... I was worried that (even though the after-pump filter was more or less clear) some of the crap from my tank had found its way to the injectors and would be causing problems... An injector going down could be pretty catastrophic, yes?
    Anyways, they're back in, and I'm more than happy Cheers Clint!
