Results 1 to 6 of 6
Thread: How is PCV valve connected? Escort mk2 RS2000
    Dec 2009
    Netherlands
    413
    19
    hi,
    I am rebuilding my mk2 RS2000 back to original spec.
    Does anyone know where to and how the PCV valve is connected?
    Looking for originality so no catch tanks allowed
    A photo would be even better
    regards,
    Ruud
    Re: How is PCV valve connected? Escort mk2 RS2000
    sorry dont have any pics but its connected to an elbow on the intake manifold
    4,889
    Click image for larger version Name:	a591328-19072007141.jpg Views:	59 Size:	62.5 KB ID:	81458
    9,204
    Pic looks odd ? Generally the large separator plugs into block and the Valve plugs in to that (on end of pipe)
    Or the same setup but large unit replaced by a small barrel again wedged in block. I may be wrong but I don't remember the above setup with large unit into a smaller adapter.
    Jan 2016
    Hull
    246
    Aladdin is correct the breather box is direct into block (push fit) some may also have a m6 bolt or 1/4 unc as a secondary means of holding the box to the block. The PCV valve is in the end of a moulded pipe pushed into the large rubber ring on top of box then to an elbow on inlet manifold.
    4,889
    You are right ofcourse should have looked better at the photo before posting ...
