BF134 cam fuel and timing advice
Hi All,
looking for some advice please. Running the bf134 cam and a 2ltr Pinto with 32/36 Weber on comp ratio 10:5:1. Only have the timing at 10 btdc and I'm getting pinking when i labour the engine. I have just been using standard unleaded. Any suggestions on timing or fuel?
Re: BF134 cam fuel and timing advice
Any help would be appreciated
Set it to 6 degrees BTDC at idle with vacuum disconnected.
