hi there i was just wandering if any one had any wiring for a mk1 rs2000 preferably the bulkhead plug for the main wiring loom or could give me any advice on where to look thank you.
very doubtful you will get an engine bay loom rarer than hens teeth been looking for one for years for a spare as the plug on the alternator wiring loom had a Brocken terminal in side it. what loom do you have at the moment, do you have any pictures if you have the right plug for the fuse box engine bay you can convert it quite easily the dash side its the same as any six diel dash you need the brake test wire for the switch to the brake pressure valve if its not with the dash loom you will also need the hazard warning light and loom and the heated rear window loom
