Results 1 to 6 of 6
Thread: Pinto 205 block
    Nov 2013
    france
    75
    103
    Pinto 205 block
    Hiya P,heads
    Anybody used the Melling M86CHV oil pump on a Pinto
    A high volumne oil pump as different to a high pressue oil pump
    whats needed ?
    More pressure or more volumne.
    Or stick with a standard Burtons ?
    25,099
    Re: Pinto 205 block
    i havnt, but you need nothing more special than a standard oil pump.
    most replacements are not very good and wear out relatively quickly, where possible for a fairly standard engine i prefer to use an original ford pump thats still in good condition.
    but from what i read you wont go far wrong with this one
    http://www.ebay.co.uk/itm/Premium-Fo...4AAOSwEa5XPvS5
    Nov 2008
    Adelaide, Australia
    1,331
    96
    Re: Pinto 205 block
    whats needed ?
    Remember that pumps don't put out pressure they only put out volume.
    A higher volume pump will always produce more pressure if nothing else is changed as it is trying to squeeze more oil through the same hole (galleries). Low revs, pumping low volume = low pressure. High revs, pumping more volume = high pressure.
    The old thinking used to be 10psi per 1000rpm but these days 60psi hot seems to be considered fine.
    There are ways to get more pressure from a standard Pinto pump by shimming some bits inside. This prevents the by-pass function coming in too early. There are threads on this.
    I have not used the pump you mentioned.
    Jul 2014
    Aberdeenshire
    Re: Pinto 205 block
    The Melling M86CHV does not fit the European pinto engines. I bought one, tried it, doesn't fit!!
    They only do a standard volume pump that fits our pinto.
    Google M86CHV and go to images then compare it with the standard pump...completely different!!
    If you still don't believe my I'll very happily sell you the one I have in my garage.
    But seriously don't waste your money.
    Kev.
    Jul 2014
    Aberdeenshire
    Re: Pinto 205 block
    I think it's the M86B that fits our engines...possibly!!
    4,875
    Re: Pinto 205 block
    My 2 cents: if you have an oilcooler fitted, use a high capacity pump.
