Results 1 to 4 of 4
Thread: Duratec 2.0l on Webers Coil Pack Lead Configuration
    Aug 2008
    Queensland,australia
    492
    Guys been using EFI for several years with Coil over plugs however the latest build is on Webers. The car runs fine on idle but drives shocking. I think the Spark Plug lead configuration is incorrect. I know the Firing Order from Front to Rear is 1.3.4.2
    Their appears to be so many different Coils for the DURATEC. I have a Bosch one fitted with the Outlets marked from 1-4. Should I rely on the numbers stamped into the Coil or should I look at something else.?
    Any help much appreciated
    9,212
    168
    If your using wasted spark then 1-4 ,2-3 fire together anyway.
    Depending what's driving the coil pack you can wire the 2 coils backwards but in either case if sure that idle would be on 2 or 3 cyl.
    Aug 2008
    492
    Re: Duratec 2.0l on Webers Coil Pack Lead Configuration
    Thank you it's using an MBE Ignition only ECU
    If it idles i would be looking more at the carbs. If you take a lead off and idles worse you know that it was ok in the first place.
  5. The Following User Says Thank You to wildo105e For This Useful Post:
