Page 3 of 3 FirstFirst 1 2 3
Results 81 to 101 of 101
Thread: The Ultimate Mk1 Fiesta?? ;-)
  1. #81
    Mar 2004
    Harlow, Essex
    14,285
    318
    Re: The Ultimate Mk1 Fiesta?? ;-)
    Well done lads
  2. #82
    Mechanic andygfc's Avatar
    May 2006
    kent
    567
    Cracking build, love it
  3. #83
    Mar 2003
    Now over the pond North side
    3,540
    Well, my job was to sort this lot out!!
    Was considering using the Subaru loom complete to run the whole car, then had a change of heart
    Chose to just use the ECU to run the engine. So, had to make up a loom to fit the car!
    Whilst I was busy with that, Scooby removed the engine and box, fully wetted it, fitted the clutch and flywheel and re-fitted it all. Then he moved onto this...
    Because of the way we have cut the engine bay out from the ImpreZa, we didn't have the mount to brace the clutch pedal, so it was a bit 'wobbly'!!
    So, Scooby came up with a way to brace the clutch pedal and brake pedal at the same time
    That should help brake feel
    Because I was still 'fafing' with the loom, Scooby decided to finish something we had started earlier....
    Rear subframe starting to look really good
    In this time, I'd managed to reduce down the loom a little. In fact, this is the piccie of the loom after we had ran the engine. It's not finished as I'll tidy it all up and mate it to the original car loom later.
    We haven't got that many piccies as we were using a camera with only a 32MB card in it!!
    One cool looking subframe!
    BEFORE
    AFTER
    WITH DIFF FITTED
    Looks even better on the car
    Dazzle
  4. #84
    Mar 2004
    Barking Essex
    9,033
    262
    that is a pukka job you are doing there, very nice indeed
    Old skool forever
    Just don`t tell the wife
    how much it really costs!
  5. #85
    25,110
    yes some loverly work there
  6. #86
    Feb 2007
    Hillingdon
    2,107
    21
    wish i could see these pics here at work
    My Project... Fiesta D-TEC
  7. #87
    Nov 2004
    Sunny Essex
    4,831
    100
    Great work on the rear axle, looks very good
    Mar 2003
    3,540
    Quote Originally Posted by david_white View Post
    Many thanks Dave
    Well, to be fair, not a lot got done in November (Courses, work and other stuff!), December (Work and that Christmas thing!) and January (Work out of the country and lot's of Snowboarding ) So it's now February and what's been done?? ...................
    LOTS!!
    The 2 of us have taken leave at the same time so it's full steam ahead
    This, if you remember was how we dealt with the diff cradle mount.
    And this was how we set up our extended tramp bars (probably called trailing arms??)
    Well, we started to look at our rear anti-roll bar and was trying to see where it would fit and what we would use!
    After playing with a fiesta bar, then the subaru bar, we came to a traumatic realization!!
    We hadn't given the rear roll bar enough thought/respect and had mistakenly thought we would be able to fit it in anywhere at the back. This wasn't to be the case!!
    So, when we finally worked out something had to be done, we decided the diff cradle arms were in the way. This actually turned out to be a blessing in disguise as Scoobs wasn't entirely happy with where we had mounted the arms and also they were going to be in the way of the air flow to the radiator!!
    So, we set about having a bit of a change round
    We decided we wanted to mount the support arms closer to the front of the diff carrier, replicating where they are mounted in an ImpreZa and to also move them closer to the Fiesta floor so it moved them out of the air flow.
    Please forgive us, because it's been a while since we have worked on it, we forgot to take piccies until mid morning so we have missed the first few!!
    Our new/revised cradle support arms. We have modded them so we can take it apart to remove/fit
    Empty, nothing fitted apart from rear cradle
    Diff, diff cradle and new support arms and starting to fit suspension with our new link arms.
    So, with everything fitted up and now having some more room, we knew we would have to fit the roll bar in front of the cradle, so we had to change round our link bars.
    This lead to problems with the drop links hitting the bottom of the struts! So, we decided to make new brackets for the drop links so they would fit higher (or lower when the cars on it's wheels )
    Old brackets cut off and bars cleaned up/linished.
    New brackets made up and trial fitted.
    Drop links trial fitted and clearance no longer a problem
    So, suddenly a lot going on and a lot of too-in and fro-in meant with a lot of other things to think about, we forgot piccies again!!
    We offered up the original ImpreZa roll bar and decided it would work.......well, it would if we cut the ends off
    We decide we would 'adjust' the ends and fit our own 'blade' ends!!
    With a little help from some friends, we had our 'blades' and an 'endless' bar, so all we had to do now was work out how we was going to fit it
    We had a good look at it all and we worked out we could pick up on our already present chassis rail. We decided to use the original brackets to make fitting a lot easier
    So, it was time to box our chassis rails in and what better to use than some high quality aircraft spec steel
    With the fixing brackets cut down, we started to work out where it was all going to fit and the best way to mount it all
    Due to the lengths of the fixing bolts, we decided to drill some holes for them to pass through
    With them in the right place (well, where we wanted them anyway ) it was time to 'welderize' them and box them in.
    Then it was time to fit the blades and of course, they needed welderizing as well
    To make sure we got good penetration from the welds, we heated the blades/bar before welding
    We finished up the ends to make them look better.
    (That handsome fella in the background is the welding god/genius Scooby )
    So, it was fitting time and everything looks GREAT!! To say we were happy with that, would be a bit of an understatement
    Dazzle
  9. #89
    Mar 2003
    3,540
    A reminder of our trailing arms/tramp bars. We always knew we weren't going to leave them like that, and with some in-line adjusters ordered, we decided to make our new arms
    New arms, cut then bent, welded then braced with some 'gussets'. New brackets made then welded to the new arms and then braced.
    Were we pleased?? Oh yeh
    All our new kit fitted and connected. Hopefully our adjusters will turn up tomo so with them fitted I believe that's the back end of our car (suspension/drive train wise) finished
    Not bad for 2 days work eh and we've still got at least another 5 days to go (it will probably slow right down now )
    I hope you all like
    Dazzle
  10. #90
    Oct 2004
    get me on my beeper,beeper
    11,882
    toip work dazzle,looks fantastic and really well thought out mate,keep the updates coming and daily lol
  11. #91
    tuk and poke me Decade Plus User mogsmex's Avatar
    Jul 2002
    essex, innit !
    2,763
    9
    looking good chaps, nice to see it still going
  12. #92
    Mar 2003
    3,540
    Quote Originally Posted by mogsmex View Post
    Hopefully start on the Mex soon, once I've sold all my tosh (Though that is taking some time!! )
    Dazzle
  13. #93
    Mechanic rampant racing's Avatar
    Nov 2008
    sarnia ontario canada
    58
    521
    10
    lovely work fella's.that's some undertaking guys.you've both got balls of brass.cheers
  14. #94
    World Champion Decade Plus User markb's Avatar
    Feb 2003
    Plumstead
    6,821
    10
    very impressive!
  15. #95
    Oct 2018
    Sunderland
    Hi mate,
    I've been a MK1 fiesta lover all my life and still are.
    Seen your build ages ago and ive looked at it 100's of times!
    Please tell me you lads got it completed or did more work to it?
    Just registered just to send this lol, has to be the best build ive ever seen!
    Yous have done the most epic job!!!
    I just need to see some more, did yas finish? or is it still going? I hope so!
    Kind regards Dave
  16. #96
    Mar 2003
    3,540
    Quote Originally Posted by Mrt2K18 View Post
    Hi mate,
    Kind regards Dave
    So, I just came on here to look back at some pictures to remind me of some things and I've just seen your message!
    Good news is, I'm hopefully going to be starting back on with it this year
    Lot's has happened, I now live in Canada so it's just me on it, not Scooby
    And it's going to get built as a track car now so hopefully that will work out well??
    Dazzle
  17. The Following User Says Thank You to dazzle For This Useful Post:
  18. #97
    Dec 2019
    Yugoslavia
    28
    176
    9
    great thread!
  19. #98
    Apr 2016
    Langley BC
    96
    Welcome to Canada
    This looks fantastic. Are you keeping the Fiesta RHD?
  20. #99
    Mar 2003
    3,540
    Quote Originally Posted by Langlia View Post
    Welcome to Canada
    Thanks for your welcome. I've had the pleasure of being here for over 7 years now, definitely lots happened in that time!!
    Yeah, it will stay RHD. I did consider converting it but just didn't see the worth.
    Dazzle
  21. #100
    Apr 2016
    Langley BC
    96
    Did you land in the East or the West?
    Yes 7 years is a long time. I know a guy who has finally got his Anglia together after almost 20 years I've been told!
  22. #101
    Mar 2003
    3,540
    I'm in the West, Calgary to be precise
    Dazzle
