Results 1 to 9 of 9
Thread: Off set woodruff keys
    Nov 2013
    france
    75
    103
    Anybody know if these offset woodruff keys fit the pinto crankshaft they are from the new mini
    Attached Thumbnails Attached Thumbnails image.jpeg‎
    25,099
    Re: Off set woodruff keys
    you use offset keys on the cam shaft not the crank. they defiantly wont fit the crank
    Nov 2008
    Adelaide, Australia
    1,331
    96
    Never seen those before. Are they used as a way of changing cam timing?
    2,654
    267
    Me neither, but I would have thought they'd be used in a similar way to offset dowels or even a peg type cam pulley.
    25,099
    you guys are too young! in the days before verniers that was how you altered cam timing, you would build the engine using standard sprockets etc, measure the timing to see how far out it was and then use offset dowels or woodruff key to correct
    25,099
    yep exactlt the same as an offset dowel
    Mar 2012
    2,118
    Correct, you could get them everywhere.
    Today I make the keyway in the pulley wider to the size I want to move the cam. I fill up the other (drive) side until I got my correct setting. The filling is only needed for the position and can be anything you find. Weld rods, thin metal plates etc... Once position is right, torque the camshaft pulley bolt and done. BTW, you do not even have to fill up the gap on the drive side but makes setting much easier. On the dyno, for quick changes of setup I use nothing than the torque of the bolt. If anything go wrong it can only move a very little before it the key lock the drive. Very cheap, takes 2 minutes with saw to make the gap wider. Saves +/- 100 - 150 € on most engines.
    25,099
    and on engines with dowels, we simply timed then without a dowel and the drilled our own hole and pinned it ignoring the factory stuff
    Nov 2013
    france
    75
    103
    Good info
    And as Graham also quotes often ,Dont waste money on it
