Results 1 to 21 of 21
Thread: fan thermo switch on pinto
    9,204
    wheres the best and easiest place to put a thermostat switch for a rad fan on a pinto in a mk2 ?
    rad is standard type with no boss.
    2,659
    268
    Re: fan thermo switch on pinto
    I had a similar kenlowe item in mine years ago. Mine was sealed in the top hose with a sticky pad between the rad pipe and the hose then just tightened up well. I never had any trouble with it..
    http://www.ebay.co.uk/itm/Aeroline-C...gAAOSwg3FUpsPR
    http://www.ebay.co.uk/itm/32MM-HOSE-...oAAOSw2xRYUq1D
    Or something like that, again in the top hose just cut an inch or so out an put that in there.
    9,204
    yes i was considering the hose insert (i have switches here) - cheapo here
    http://www.ebay.co.uk/itm/32MM-Car-W...AAAOSwTA9X2~Ol
    but not sure if it will go in top hose neatly due to curves.
    2,659
    268
    Well that says it's 68mm long, so have you got a straight section 68mm long on the hose?
    If so then it should be alright...
  5. The Following User Says Thank You to rallyrob For This Useful Post:
  6. #5
    9,204
    Looking today there is more room in top hose than I pictured so I think I will order one up.
    Anyone know if Zetec has a thermo switch with a 1/8 (10mm ish) thread in the stat housing? I have some here but not sure if it's a switch.
  7. #6
    a lot of fan contollers now have a probe which simply pushes into the rad core itself
  8. #7
    I just had a boss fitted to the rad and used a standard ford fan switch screwed into it.
  9. #8
    9,204
    yes, most new rads have a boss as std these days but its a very budget "parts bin" install so i will get a cheapo hose adapter . only issue is that most switches seem to be m14 thread so i will need to see if i can re tap it or find a 1/8 npt switch.
    i have run a switch wire to dash for a manual operation but thermo would be nice.
  10. #9
    The rad place I use would do it pretty cheap just get it fitted in the right place as I found out first time 😳switches are about £6. Are the m14 ones for the ecu feed ? I use one like you find on a mk1 fiesta etc to switch the earth on the fan👍
  11. #10
    Jun 2015
    Hampshire
    27
    And they will work accurately enough in the bottom hose as well.
  12. #11
    9,204
    What's the thread on that fiesta switch?
    I see motorsports tools do an adapter with 14 thread ( lots of fords seem 22 also)
    Just trying to match what I have on the shelf. I need to test a few.
  13. #12
    I would think it would be the 22mm as they are quite a large size part XEFS5 on burton looks about right. they are available at any car factor a lot cheaper.
  14. #13
    9,204
    i cant find an alloy adapter with a 22mm thread which is odd really, i know i dont have a tap that big. may need a rethink but need to check all my junk boxes
  15. #14
    2,659
    268
    Are you sure the 22mm is not refering to the spanner size, a 22mm thread is going to be huge.... So it would probably be an m14 thread....
  16. #15
    9,204
    Yes 22 X 1.5
  17. #16
    I know i use an adjustable to fit it, they are quite a large thread.
  18. #17
    Jun 2015
    Hampshire
    27
    How about one of these
  19. #18
    2,659
    268
    Yes 22 X 1.5
    Yea sorry I realised that after saying it. I had a look at one, they are bloody large aren't they...
  20. #19
    9,204
    Quote Originally Posted by andyf1140 View Post
    I can't weld it :-/
    I have a 14 tap so I think I will order a cheap adapter and see what meat it has. Possibly order a 22 tap if it looks like it will go but tbh 14x1.5 switches are available
  21. #20
    Jun 2015
    Hampshire
    27
    I can't weld it :-/
    I was able to get a pipe with the 22mm boss pre-welded on it but I can't find the supplier now. There are plenty of 14mm adaptors available for different size pipes though so I would go that way if you don't have a specific switch in mind. Also don't forget to use a relay unless you know for sure that the switch you are using has a high enough rating to drive the fan.
  22. #21
    9,204
    👍 already wired in
