Vauxhall C20XE engine and conversion parts
Hi all,
i am selling off my C20XE engine and conversion parts, this is to fit the engine in at 7 degrees as I had a manta sump setup I have sold previous to this ad.
i hope the pictures work as Photobucket has stopped me using them to share pics, if it doesn't work please pm me and I will email you some pictures. They are too large for the site uploader.
here is a 7 degree bellhousing to take a type 9, standard new clutch, spigot bearing, release bearing and clutch arm £280 + postage.
https://i.imgur.com/cjl9LBw.jpg
https://i.imgur.com/UJlklC3.jpg
here are some 1.8 manta engine mounts - £40 + postage
https://i.imgur.com/gpOXoFU.jpg
chassis (weld in) engine mount kit - £55 + postage
https://i.imgur.com/UvMxJen.jpg
manta 1.8 adjustable distributor with bracket, belt, pulley, control box and engine cover - this is an easy way to get the engine working as you don't need an expensive ecu system, just a set of carbs and this for your timing - £225 + postage
https://i.imgur.com/TfWDzYK.jpg
https://i.imgur.com/pOwFDdO.jpg
oil catch can - £10 + postage
C20XE engine, 130k no smoke, cracking engine and was well known for making a quick Astra gsi locally, comes with engine loom, oil cooler, clutch/flywheel and starter motor £350 with super chipped ecu £400
https://i.imgur.com/QzxifaE.jpg
https://i.imgur.com/eUiwsh3.jpg
https://i.imgur.com/itb8GOZ.jpg
22mm front mk2 escort anti roll bar - £40 + postage
https://i.imgur.com/gouxEYZ.jpg
collection is just off of junction 22 of the M5 in Somerset.
thanks
kris
Re: Vauxhall C20XE engine and conversion parts
Engine is sold
Dizzy setup sold
Kris
still has for sale manta 1.8 adjustable distributor with bracket, belt, pulley, control box and engine cover?
You can ship to Portugal?
Roberto
Sorry I Have sold everything now
