Results 1 to 12 of 12
Thread: Coilover helper spring
    Tyre Kicker Miguel Costa's Avatar
    Nov 2011
    Portugal
    29
    17
    Question Coilover helper spring
    I was searching for helper spring for my mk2 escort (trackday/hillclimb car), and I notice that there are several spring rates, and I have no idea which rate I will choose. Currently running with 2.25x10.5x180lbs main springs, unknown inserts.
    Wonder if anyone can advise which is the best rate for this purpose?
    Re: Coilover helper spring
    Are these front springs Miguel?
    Nov 2011
    Portugal
    29
    17
    Yes it is.
    4,893
    I would get the lowest spring rate you can buy, especially with 180 lb/in springs.
  5. The Following User Says Thank You to Miniliteman For This Useful Post:
  6. #5
    I am not quite sure what you are meaning by helper spring Miguel, can you enlighten us more.
  7. #6
    Nov 2011
    Portugal
    29
    17
    Maybe with an image it will help.
    Click image for larger version Name:	Helper2.25-4Inch_19.jpg Views:	98 Size:	7.9 KB ID:	81606
    Click image for larger version Name:	Strut_Helper_Spring_Close-Up.jpg Views:	97 Size:	23.2 KB ID:	81605
    It really depends on what youre trying to achieve, if its to make the travel more progressive then you have to match the helper spring close to your 180ld spring otherwise the intitial travel will be too soft and you'll get a quick suspension movement followed by a slower one, meaning the travel wont be progressive, it will be jerky.
  9. The Following User Says Thank You to Erikmex For This Useful Post:
  10. #8
    Quote Originally Posted by Miguel Costa View Post
    Attachment 81606
    Attachment 81605
    We used this type of helper spring on a Group A Cosworth, the only purpose it served on our car was to hold the spring in situ when the suspension was on full droop. The spring was of very low poundage and would compress when the weight of the car was applied to it. if you look at the thin coils on the helper spring you can see that this can serve as no other purpose.
  11. The Following User Says Thank You to Forest_rallying For This Useful Post:
  12. #9
    That is my understanding of them, I assume in rallying if you leave the ground enough you could unseat the spring. Or when you lower your car off the jack it stops that big clang as the spring seats back again.
  13. #10
    Dependant of what poundage you select, if the spring wont fully compress under the weight of the car it will act like a progressive spring in conjunction with the main spring.
  14. #11
    Mechanic davemk1's Avatar
    Jul 2011
    herts
    502
    This is what I thought they were for as well!
  15. #12
    Feb 2005
    oxfordshire
    62
    Eibach make 'tender' 2.25" springs that actually do have an effect on suspension:
    https://eibach.com/de/en/motorsport/...ing-system-ers
Tags for this Thread
