Results 1 to 9 of 9
Thread: Mk6 fiesta removable steering wheel HELP
    Bodger scoobymike's Avatar
    Oct 2014
    south wales
    62
    176
    This one is for the electrical boffins out there,
    I have a mk6 fiesta that I'm converting to RWD , as an added security measure I want to fit a removable steering wheel, how would I get around the airbag warning light.
    I,'ve heard about the alternator fix, but was wondering if there,s an easier fix, cheers
    Sent from my SM-T560 using Tapatalk
    9,204
    Re: Mk6 fiesta removable steering wheel HELP
    whats the alternator fix ?
    as a guess i would say measure resistance of an airbag and replace with similar resistance in the wheel circuit after wheel removed.
    Oct 2014
    south wales
    62
    176
    Alt fix. Is take a feed of ign side so when u turn on ignition airbag lights up as suposse to. Then when started goes out. MOT guy then thinks everything is ok. 😆
    9,204
    Ahh I see , I thought you were trying to fool ecu.
    I think alt method is easiest there is for modded car especially as you may delete airbags ? You can just link bulbs on clocks I guess even oil light should do.
    linking the airbag light to the alternator or oil switch will NOT produce the correct sequence of light operation, so it should still fail an mot.
    2 ohm resister across the air bag plug, will put the light out, its one method we use for fault checking, incidentally if the airbag light doesnt come on at all its not a fail!!!
    as for the mot man, well that depends on who is testing, an air bag missing from a vehicle where it it was fitted as standard equipment is an mot failure whether the light is on or not, i cant think of one car which doesnt have a steering wheel airbag, so without doubt it would NOT pass an mot at my place.
    Oct 2014
    south wales
    62
    176
    Hi Graham. Thanks for this input. I've not tried the Alt fix myself. But no someone who has . That's how I got to hear of it. Cheers
    Oct 2014
    south wales
    62
    176
    I just Wana fit removable string wheel . For security reasons. OOh plus a steering wheel I found I like the look if. Thanks
    Oct 2014
    south wales
    62
    176
    Quote Originally Posted by scoobymike View Post
    I just Wana fit removable steering wheel . For security reasons. OOh plus a steering wheel I found I like the look of. Thanks
    thats fair enough, although i think i would prefer a working airbag just in case, and you most defiantly will need to declare it to your insurance company, all i was trying to do is point out you will need to get a bent mot next time!
