Results 1 to 6 of 6
Thread: Cosworth P8 WASTE SPARK / DISS solution
    Jun 2012
    Slovakia
    So guys,
    who wants to have WASTE SPARK, DISS..without any HW mods inside ECU? only software change inside bin file, and of course you need to wire 2nd ignition output from ECU, new amplifier...etc
    Solution is for FREE!!!!
    Jul 2016
    Spain
    12
    Re: Cosworth P8 WASTE SPARK / DISS solution
    I would like to know how to activate this one
    Clint's Avatar
    Jul 2001
    933,664
    You need to either use Fiat software or hacked Pectel software, post the solution in this forum here: http://www.turbosport.co.uk/forumdisplay.php?f=248
    Mar 2008
    west bromwich
    1,861
    And me
    Jun 2012
    Slovakia
    send PM with mail, send bin files..I will enable DISS free...
    Jun 2012
    Slovakia
    To Enable WASTE SPARK, DISS in EVERY P8 ECU software (Fiat, Lancia, Ford)
    Find address 07DF in hexeditor (or 87DF with offset)Default value at this place is "64" (hex mode) = this value 64 means "0" for ECU.
    ECU code has option for selecting Ignition driver mode (with distributor or without) so "64" = with distributor. Change this value to A0 or B0 = without distributor ...think its not very important (just higher than 64)(try and report)
    Now ECU will use 2nd spark output on PIN 26.
    In this setup you need to rewire your ignition system:
    PIN 24 - ignition ground
    PIN 25 - Ignition trigger for 2/3 cyls
    PIN 26 - Ignition trigger for 1/4 cyls
    You need to buy Ford EDIS 2x2 coil and another Ignition amplifier. Ground is same for both amplifier, just triggers on PIN 6 (amplifier) are differend (first amp is from ECU 25, second from 26)
    at last, dont forget to disable checksum controll (or calculate new checksum).
