Results 1 to 7 of 7
Thread: Pinto Injection upgrading
    Oct 2013
    LTU
    63
    Hello all,
    I've been reading this forum for quite a long time and as far as I have seen the majority of naturally aspirated Pintos are tuned using carbs, however I do not have experience with it and honestly not very interested in using carbs, therefore I want to build stronger Pinto using fuel injection.
    I already completed (for this moment ) Pinto turbo project with fairly good results, now I have another Sierra with EFI, this is "iS" version with 85kW in stock. My plan are as follows:
    1. As I already have freshly rebored and honed short block, I will use it. It has +1mm stock cast pistons and rods, I think they are KS "carb version" as I have seen such in carb models while EFI has slightly different rods and pistons (Mahle). Are they any different?
    Click image for larger version Name:	20171008_125304.jpg Views:	106 Size:	127.8 KB ID:	81638
    2. REC oversized valves (44.4 and 38) in standard length and triple groove, the camshaft could be Kent FR30/FR34 or Burton BF134, not sure which is better yet. I think the max revs will be 6k or similar. Some porting and cleaning.
    3. Raised CR to 10-10,5.
    4. Already have Kent adjustable pulley for optimum cam timing, Ashley complete exhaust using 4-2-1 runners.
    5. Already have programmable piggy back which could be used to fine tune fuel and ignition timing.
    6. Maybe a 74deg thermostat.
    The main question is how much power could I expect from such build? It is relatively budget build as I want to avoid buying forged conrods/pistons and other expensive stuff.
    Re: Pinto Injection upgrading
    around 135bhp, perhaps 140.
    re pistons and rods, most sierras have the later beefier wide beam rods, although they are not actually much of an upgrade.
    pistons are same but different! for all practical purposes they are the same, later ones use narrower rings, which probably gave a tiny efficency/emission improvement
    Mar 2012
    2,118
    I believe left piston is Mahle, right piston is KS but not 100% sure. Ford has been using both, after market, most sell KS and little cheaper.
    For single throttle body setup I would use BF134 all the time. You wil indeed end round 135 Bhp with a correct modified head.
    Clint's Avatar
    Jul 2001
    933,169
    Mahle is the better piston, a lot better made and will ultimately handle more power, they come with the thinner rings too.
    Oct 2013
    LTU
    63
    The 20 bhp increase is not that much after all, is it even worth bothering and making bigger valves over stock ones ? I understand that the biggest issues are single throttle manifold and lack of RPM ?
    bigger exhaust valve will probably do nothing, ive had 200bhp on 36mm ex valves. the bigger inlets are well worth having.
    your correct its not going to rev hense bhp figure will look lowish, BUT your still looking at about a 20% power gain which isnt to be sniffed at, and you will gain a lot of torque over standard
    Mar 2012
    2,118
    Best setup for making real torque AND power, fit a set of Webers. Maybe you are not very much interested in carbs but at this entry level budget, they beat you any time in a NA engine.
    A mild tuned Pinto can easy make 150 - 160 Bhp with very good torque. A number you can never reach with single throttle body.
    Or use ITB if you want to stay injection. It's the 4 throttle plates you need
