Results 1 to 13 of 13
Thread: The Wildest Escort Ever - Very Custom Mk2 Rally Car (Pic Heavy)
    Feb 2007
    USA
    The Wildest Escort Ever - Very Custom Mk2 Rally Car (Magazine Feature)
    A project we have been working on for quite some time. It has already done a few events and won some stages overall here in the USA. Running a standard V6 motor from a Ford Mustang. Motec ECU puts the motor at about 350hp and 300ft lbs. I'll let the pictures do the rest of the explaining. Car was built by the team at JRD Rallysport http://www.jrdrallysportusa.com
    Engine:
    3.7 liter Ford V6 with stock internals. Dailey Engineering/Ginetta Dry Sump System, BBK Throttle Body, Griffin Aluminum Radiator, Setrab Oil Cooler, and Stainless Exhaust with Dual JRD Full Flow Racing Catalytic Converters 350hp@6500rpm, 320Lbs-Ft@4300rpm. Tuned by Ed Senf of Engine Management Sales
    Control Systems:
    Motec M130 ECU, Motec PDM 30, Motec C127, Race Grade Switch Panel, JRD Steering Wheel Control Panel, Motec LTCD 4.9, Jay F. Yue Motorsports Wiring Harness
    Driveline:
    Saenz TT3-D6S 6 Speed Sequential Gear Box, JRD Shifter and Linkage, Quartermaster Flywheel and Clutch with Reverse Mounted Starter, JRD Custom Aluminum Bell Housing, Steel Drive Shaft, Strange Engineering 9 inch Light Weight Aluminum Casing with 3.89 Final Drive Ratio, Hollinger LSD Ramp Diff (from V8 Supercar), Speedway Engineering Bespoke Ford 9 inch Rear Axle with Floating and Crowned NASCAR Axle Shafts (to make camber and toe-in possible), Speedway Engineering Mod Lite Aluminum Rear Hubs
    Chassis:
    Original shell was scanned and turned into a Solidworks 3D CAD model to serve as a base for the new purpose designed rally chassis. 8 Point Roll Cage, Front Mid Engine Layout, Enlarged Wheel Houses and Shock Towers, Raised Tunnel, JRD Strut Brace, Quick Disconnect Front Nose Section, Seam Welded and Powder Coated, 10 Gallon ATL Fuel Cell with JRD Aluminum Enclosure
    Suspension:
    Suspension geometry has been calculated and designed using Performance Trend Suspension Analysis and Solidworks 3D CAD software.
    Front: Tubular Sub Frame with JRD Billet Lower Control Arms and Steel Compression Struts, Modified Mustang Uprights, Mustang Hubs with APR Studs, Short Escort Motorsports Rack, EPAS from Corsa B with Controller from Simtek, In-line Steering Quickener that can be altered between 1:1, 1.5:1 and 2:1, 45 degree Steering Angle and 1.5 Turns Lock to Lock (w 1.5:1 Quickener), JRD/Öhlins 3 way TPX with PDS and 198mm Stroke, Öhlins Springs, JRD Top Mounts
    Rear: 4-Link Suspension System with Watt Linkage, Öhlins 3 Way TTX 210 mm Stroke, JRD/PAC Racing Sway Bar, JRD Top Mounts
    Wheels/Tires:
    Pirelli 205/65-15 on Enkei 7x15 Rims for gravel
    JRD Would Like to Thank: Seamus and Joseph Burke, Niclas Jancic, Jay F. Yue, Auston and Andrew Cain, Ingvar Gunnarsson and Martin Claesson of IGMAB, Christer Lööw of Öhlins, Lazer Lamp, Ed Senf and James Whisler, Allen Lopez of TheWrapDepartment.com, Keith Merritt, Tyler Crawford, Ben Paddick of Raceparts USA Ltd, Perfect Edge and our sister companies within the Panoz Organization
    3,641
    Re: The Wildest Escort Ever - Very Custom Mk2 Rally Car (Pic Heavy)
    Stunning build
    Feb 2007
    USA
    Video from 1st Event, car was down about 75hp to where it sits now
    https://youtu.be/lyV0hnYGW8Q
    Aug 2015
    Leeds
    767
    Awsome build
    May 2010
    london
    1,139
    cool build...
    May 2010
    london
    1,139
    cool build...
    May 2016
    Germany
    288
    63
    stunning details...would llike to see more details from the build phase!!
    9,211
    Mechanic davemk1's Avatar
    Jul 2011
    herts
    502
    Somebody scrape my tongue off the floor please!
    Feb 2007
    USA
    Shaker rig testing at Ohlins yesterday
    https://instagram.com/p/BaEmxelngk4/
    Tyre Kicker Gaz15's Avatar
    Feb 2008
    Ireland
    58
    This is a really nice build.
    Think it needs to brought home for a run round Donegal in June??
    Pit Crew 5tox's Avatar
    Jul 2012
    cambridgeshire
    1,054
    That is a great escort
    Feb 2007
    USA
Tags for this Thread
