Results 1 to 12 of 12
Thread: BDA Cam carrier to head gasket
    Sep 2005
    California USA
    284
    58
    Does anyone have experience with the BDA cam carrier assembly and in particular the gasket that appears on the engine exploded view between the cam carrier and the top of the head.
    How thick are these?
    What is the correct name for the gasket? and any advice on sourcing as they are not in the Burtons 'complete' kit i received, and i don't see them on the site.
    James
    4,888
    Re: BDA Cam carrier to head gasket
    Hello James,
    there used to be a very thin paper gasket in the set. Very thin otherwise it would/could upset the valve clearances.
    I used one on my first BD 20+ years ago but it was very prone and didn't seal properly.
    Instead I use a pro flexible gasket maker (tube); it is on a rubber basis (non silicone).
    You need just a very small layer of it as most of it is pushed out when you put the camcarrier onto the head.
    Regards, Leon.
  3. The Following User Says Thank You to Miniliteman For This Useful Post:
    I support TS Turbosport Subscriber sholdowa's Avatar
    Christchurch, New Zealand
    64
    521
    35
    Hello James,
    Regards, Leon.
    Hi Leon,
    I have the same problem with a Lotus 907. What product do you use?
    Cheers, Steve
  5. #4
    4,888
    Hello, it's Easy Gasket from Innotec.
  6. The Following 2 Users Say Thank You to Miniliteman For This Useful Post:
  7. #5
    Sep 2005
    California USA
    284
    58
    How do you account for tapper/shim adjustment.?
    i would imagine the final assembly would have an error due to thickness of the rubber seal. Or is it negligible?
    james
  8. #6
    25,110
    sealant thickness is negliable, dry build to get tappets correct, then final assembly with just a very thin coat of sealant, most of the sealant will ooze out when you bolt the carrier down.
  9. The Following User Says Thank You to Graham For This Useful Post:
  10. #7
    Sep 2005
    California USA
    284
    58
    Thanks, Graham.
    This is the very reason for my gasket sourcing question in the first place. I was try to account for gasket thickness for shim clearances.
    i.e. a 40tho' gasket (instead of sealant) would require an increase of 40tho' to the shim size.
    James
  11. #8
    4,888
    When using the thin paper gaskets you would have to use one every time you check the clearances.
    Take the camcarrier off, clean surfaces, and use a new one.
  12. #9
    Sep 2005
    California USA
    284
    58
    Another question Graham
    how do you hold the buckets in place when you remove. I been told magnets also some sort of spring
    assy etc.....any recommendations?
    James
  13. #10
    25,110
    i would use grease to stick the buckets in the carrier, but i t think the original ford method was use magnets to hold them in
  14. #11
    Jan 2008
    Up the garage
    2,775
    218
    Preferably you have the engine out of the car and turn the engine upside down so that the followers stay in place in the cam carrier (ie held in by the cams). Unfortunately this method may result in the shims falling out and you won't know which one came from where which is important for your clearances and any necessary adjustments.
    If you are doing it "in-car" magnets are the way to do it but they've got to be strong ones.
    The engine I've just worked on had top hat shims rather than biscuit shims and they tend to stay in place even when the engine is upside down (if there is oil in there which gives them stiction). Installing is easy upside down as there are no magnets needed, just stick the shims to the valves with grease. Again, this may not be quite as easy when using biscuit shims but the method still applies.
  15. #12
    4,888
    Before removing camcarrier (with cambelt still in place!) smear grease on the sides of every bucket when these are pushed up fully by the springs. Obviously you need to turn the camshafts (turn crank pulley) to get to every bucket.
    That way the grease holds them inplace in the camcarrier.
    Remove belt, take off camcarrier. The shims will probably fall out. Top hat shims are way better to use than the older type.
