Spot welding advice
Hi I've just bought a second hand spot welded just need to know the best way do you need to bare metal all sides and can you use etch primer .
Re: Spot welding advice
Try this screwfix product. Item number 31074
It's what I used on mine. Cleans off everything and does no damage to metal whatsoever.
You can buy weld through primer but haven't got a clue how conductive it is as I never used it because my whole shell was electrophoretic primed (e-coated) in a tank after all the fabrication work.
Metal should be bare or you can weld if the surface has weldable primer - not regular primer which will isolate the electrodes.
