Results 1 to 4 of 4
Thread: Rx8 gearbox conversion for zetec/pinto
    Jan 2012
    Whittlesey
    47
    Rx8 6 speed gearbox
    Adapter plate to go to zetec/pinto
    Custom gearbox mounts
    Braided clutch cable with new slave cylinder
    Bailey Morris single piece heavy duty prop with mk2 escort flange
    Was in a mk2 cortina with chassis mount engine
    300 collected from whittlesey
    Attached Thumbnails Attached Thumbnails FB_IMG_1507981638205.jpg‎
    FB_IMG_1507981647481.jpg‎
    FB_IMG_1507981650103.jpg‎
    FB_IMG_1507981642000.jpg‎
    FB_IMG_1507981644591.jpg‎
    Sep 2008
    Cumbria
    136
    Re: Rx8 gearbox conversion for zetec/pinto
    i've sent you a message mate
    Jan 2012
    Whittlesey
    47
    Hi mate I can't send PM's as I've not posted much on here I'm more on oldskoolford.
    TBH I've not done many miles with the box but slots in gear sweet and seems smooth. The ratios are not quite right for me as I drag a mk2 cortina with tuned st170 which doesn't get up to the revs of a rotary, so I've gone back to 2.8 type 9.
    The prop is brand new with correct splines for rx8 oil seal. It has two sets of mounts, the rear one does most of the work while the front one holds box in place when engine is out.
    Sep 2008
    Cumbria
    136
    Ok i'll have it mate, my number is 07976 409599 you can ring /text me and i'll ring you back to sort out money and collection cheers Dick
