Hi
I am thinking about where to route the dry sump pipes.
I see some have them going through firewall between the turrets, and then along the diff tunnel.
I would like to route mine through the rear wheel tub fire wall, over the wheel tub, down the rear qtr, then along the inner sill.
My worry is the height of the hose going over the tub. Not sure if it will effect the flow as both inlet and outlet are at the same height.
Not sure if its best to keep them low or not..
Opinions would be appreciated.
