XE to type 5
Hello all, Does anyone know if a xe can be bolted to a borg box? And were i couls get the adaptor plate/bellhousing from?
Cheers Josh
Re: XE to type 5
Yes you can and there is a ready made bellhousing which is sold by RACE in staffordshire which I think it is made by A-frame engineering. Sorry not sure of contact details but search the site as I know they are here somewhere. I have one if you want to know more.
Re: XE to type 5
Hi
I can supply the A Frame Bellhousing for £188.00 plus £15 P&P.
Delivery time normally 5-7 working days if castings in stock, only need machining then.
Regards
Tim
TJ Motorsport
TS Sponsor
Re: XE to type 5
Ta Quarterless, is it a cosworth clutch? What vauxhall pressure plate is used? And a cosworth release bearing?
Cheers Josh
Re: XE to type 5
As far as I remember. Cosworth clutch, Vaux HD pressure plate and cosworth release bearing. I can't remember which ones though. You will need to double check the above though.
Re: XE to type 5
Hi
It is the pinto pressure plate 1"x23 spline, astra cover, 2.0OHC Pinto release arm and bearing. You will also need 12mm std pitch bolts for fitting gearbox to bellhousing.
Tim
