Page 4 of 9 FirstFirst 1 2 3 4 5 6 7 8 9 LastLast
Results 121 to 160 of 325
Thread: Mk1 Escort Almost There... (almost)
  1. #121
    Apr 2004
    Bangkok, Thailand, Thailand
    4,346
    479
    Re: Mk1 Escort Almost There... (almost)
    Inlet manifold off...
    Plenum made for MAP sensor, as the engine wasn't behaving quite right...
    All back together, and seems a lot better... Engine is more responsive to throttle applied. Next on the list is a new radiator and fan... I took some pics on my test session today and a video of it running.
    When ticking over throttle response still seems a bit sluggish when the revs are low (below 2000) but after that it revs like a good un.
    When driving (i don't have a rev counter so i'm guessing) the engine doesn't have a lot of torque, but once it gets past 3500?? It takes off
    Is this normal for this engine? Anyone know?
    Video uploading now................
  2. #122
    Apr 2004
    4,346
    479
  3. #123
    Apr 2004
    4,346
    479
  4. #124
    Bodger hansgti's Avatar
    Dec 2008
    Bangkok
    166
    sounds a reet bag of bollox! Something definitly wrong with it, put ye old engine back in
  5. #125
    Apr 2004
    4,346
    479
  6. #126
    Mechanic Mk1_Deano's Avatar
    Mar 2007
    Maidstone
    33
    554
    9
    Quote Originally Posted by M11rf View Post
    The 4AGE in standard form has the tvis system, standing for Toyota Variable Induction System. this is an additional set of butterflies that are located in the inlet manifold. You'll notice that the old manifold has 8 inlet pipes, 2 for each cylinder, one of the two will have this extra butterfly. Below 3500rpm (but dont quite me on that figure) these butterflies are closed, thus increasing the velocity of the air entering the combustion chamber and thus creating the quick throttle response and improving low down torque below 3500rpm.
    Once the revs reach 3500rpm, the butterflies open and increases the inlet size into the cyclinder, this allows a much larger volume of air to flow at required flow rate, as is required at higher rpm to produce the grunt.
    I'm sure if you google Toyota TVIS you will find information that explains it alot better than i can but thats the basics for you.
    As on your engine you have throttle bodies from a 20v version that doesnt have the tvis. The engine will run perfectly fine without the tvis, but this will affect the low down grunt of the engine as you have experienced. Power output is not affected, so your engine will still produce the standard bhp figure, about 130bhp. Idle throttle response is also affected and is slower, due to the slower inlet air velocity below 3500rpm. but above that it'll produce good response and grunt, it'll rev right up to about 9000rpm max, 8000 is the reasonable safe limit.
    The 4AGE is not a torquey engine anyway, its designed to rev, but it can be tuned to produce more torque.
    A long response but i do hope it answers your questions and queries.
    p.s the throttle bodies sound the bollox
  7. #127
    Apr 2004
    4,346
    479
    Thanks Deano. I understand the TVIS system and the extra torque it creates. I just thought that the torque was a little low even with the TVIS off... can't have everything i suppose
  8. #128
    Pit Crew Decade Plus User GAZZAMK2's Avatar
    Mar 2006
    Exiled in Lancashire
    949
    Very nice looking install there mate, very sweet and love the trumpets
    Looks to me like an airflow speed problem may be adding to the slow low rev throttle response. Those trumpets look the dogs danglies but they have a wide internal diameter and are short, if im right that'll give slow initial response. (The long inlet may also affect it )
    Somewhere between the beer cans and the wide boys would probably be about right. Good luck with sorting it, she's a stunner
  9. #129
    Apr 2004
    4,346
    479
    Cheers mate. I have been looking into getting some longer trumpets, but nothing has come up yet...
    I have heard the same as you, but i have never had throttle bodies before, so do know how true it is, or how much difference it makes??
    I thought a long inlet was supposed to give more torque too...?
    I dunno...
  10. #130
    Spanner Monkey Med's Avatar
    Aug 2005
    Kuala Lumpur, Malaysia, Malaysia
    317
    my friend says the shorter rampipes u used, the better this 4AGE engine will response. u'll feel the power at high rev 8K to 9K rpm. he used a 20V tb too.. bigger exaust manifold may helps.. i'll ask more what could be upgrade for standard bottom end to gain power. will let u know mate..anyway, he agreed with what deano shares with us..
    well, ur mk1 looks hot!
    cheers~
    +-+-+-+-+- http://med.fotopages.com -+-+-+-+-+
  11. #131
    Apr 2004
    4,346
    479
    Cheers Med.
    No long now before you get to Bkk
    New rad and fan purchased this weekend... Need to find time to get them fitted...
    Attached Thumbnails Attached Thumbnails 5-9-09 New Rad and Fan.JPG‎
  12. #132
    Dec 2008
    Bangkok
    166
    Looks good whats the capacity on it compared to your old rad?
  13. #133
    Pit Crew Decade Plus User Blower's Avatar
    Mar 2004
    yorkshire
    that looks too nice for a mk1 escort
    though you need to get that taxi back on the road ... ASAP
  14. #134
    Apr 2004
    4,346
    479
    Not sure on capacity... But it is actually a bit smaller than the STD one, But i would imagine it will keep the car cool better because it's new and has a nice big fan.
    Taxi???
  15. #135
    Mar 2006
    949
    Look at the size of that FAN - its hooooge!
    What industrial extraction unit did u lift it from....
  16. #136
    Apr 2004
    4,346
    479
    Quote Originally Posted by GAZZAMK2 View Post
    It's not THAT big... it's the radiator that is small...
    Sounds like a line from a 'carry on' movie
  17. #137
    Mar 2006
    949
    The bigger the better i always say. Ooooh matron...
  18. #138
    ************** Decade Plus User
    Gmac's Avatar
    Sep 2001
    Locaton, Location
    10,801
    That's a corker M11rf
  19. #139
    Apr 2004
    4,346
    479
    Cooling Issues Sorted
    http://www.youtube.com/watch?v=-eeoNycT5SsYouTube - mk1 escort on the streets of bangkok.
  20. #140
    Dec 2007
    Dubai
    1,678
    29
    sounds sweet, hard to believe that is BKK, where is all the traffic??
    www.gulfpetrolheads.com
  21. #141
    Mar 2006
    949
    Sounds hard as nails that mate, good stuff
    Is that 'old steady hands' on the camera??
  22. #142
    Apr 2004
    4,346
    479
    The Video was taken at 'a non busy time'
    And yes... Old Steady Hands strikes again!!
    Not the best vid... but you get the idea
  23. #143
    Apr 2004
    4,346
    479
    Well... I bought a stand alone Apexi Power FC for the car.
    As it has had TB's fitted and still running the STD ECU, is doesn't run 100% and drinks a lot of fuel...
    It has a MAP setup for the Engine Load, and with TB's a MAP sensor is not the best as the vacuum signal is very unstable and is only good when the throttle is closed (tick over)
    I was told that the Power FC can be tuned from the TPS... I took it over to the tuners today and after an hour of head scratching... I refitted the STD ECU. The Power FC can only be tuned from a MAP or Airflow signal. So no good for my application.
    I am going to look into other options...
    Apexi SAFC maybe, although i know it wont run 100% with this piggyback, it will run better than it does now.
  24. #144
    Apr 2004
    4,346
    479
    I've managed to find and buy a Toyota Racing Developments - TRD ECU
    It's not exactly what you would call state of the art, but it is adjustable... and on the fly
    Fitted it into the car and initial tests look good... Not too sure if it really has any more power, but the plugs are retuning to their golden brown colour instead of carbon black, which should be lighter on my pocket and better for the engine.
    Adjustable camshaft pullies fitted... And a bit of a tidy up on the wiring...
  25. #145
    Feb 2010
    Co Durham, Nort hEast England
    91
    14
    Awsome,
    joined this forum 2 days ago, stumbled over this tonight and read it from the start! Lovely looking car. Family in bed, so will watch listen to video in the morning! Would be chuffed to own this. Keep up the good work !
    Jon
  26. #146
    Apr 2004
    4,346
    479
    Cheers Jon.
    Glad you like...
    Here's another video.
    I am not happy with the TRD ECU and i am now looking at getting a propper standalone.
  27. #147
    Tyre Kicker johnnynewmonic's Avatar
    Feb 2010
    fife scotland
    25
    Nice work m8 looking sweet
  28. #148
    Nov 2002
    northants
    303
    great thread, loved all the pics, top job
  29. #149
    Feb 2009
    some where
    191
    looking and going good mate keep up the good work
  30. #150
    Apr 2004
    4,346
    479
    New ECU F-con Vpro 2.1 fitted and tuned, i must say it now pulls like a train and revs a lot better and is a lot lighter on fuel!
    Changed to distibutorless ignition and coil pack also.
    I tried to get an in car video but the camera is playing up!
    I could really do with wiring tiding up, maybe the battery moving to the boot and the coil pack fitting where the battery is, at the moment there is nowhere else for it to go...
  31. #151
    Dec 2007
    Dubai
    1,678
    29
    Glad you got it running sweetly at last Mark, can't beat a good TB set-up, don't skiimp on the air filters tho'
  32. #152
    Racer Decade Plus User mark87's Avatar
    Oct 2004
    Chester, Cheshire, United Kingdom
    Have a word with Steve G at Race Engine Calibration, sponsor on here. He's pretty clued up on the Toyota set up. He'll know the best type of standalone ecu for it and how to set it up. See his videos on youtube of Mike Storrars engine on the dyno. google Steve Greenald and you'll find a whole list of dyno stuff of his.
  33. #153
    Apr 2004
    4,346
    479
    Thanks for the suggestion, but i have already had a new ECU fitted (HKS F-con pro)
    Not sure he would be able to travel to Bangkok to set it up too...
  34. #154
    Mar 2004
    yorkshire
    ... LOOKING GOOD
  35. #155
    Apr 2004
    4,346
    479
    Quote Originally Posted by dobuy View Post
    Is this good enough for you?
    It's a bit of a pain to get to fill up the brake master cylinder, because the whole filter has to be removed... But i think it looks nice.
  36. #156
    Dec 2007
    Dubai
    1,678
    29
    It is indeed, now at the risk of telling you how to suck eggs, make sure you oil it properly, as without it is phark all use
    Looks great by the way
  37. #157
    Apr 2004
    4,346
    479
    I put a little vid together today... this is with the new ECU... Revs a lot more freely.
    http://tinypic.com/player.php?v=2db8qja&s=6
  38. #158
    Apr 2004
    4,346
    479
    Painted the facia on the dash and fitted a new rev counter, also painted the cam covers...
    Picture of both the 4AGE beasts together
  39. #159
    Aug 2010
    washington
    36
    20
    Looking very sweet
  40. #160
    Dec 2007
    Dubai
    1,678
    29
    LOL well at least your paint is dry
