Hi everyone,
I have just installed my new brakes and brake lines, filled the pot up, and bled them.
The brakes still felt a little spongey, so i went to bleed them again. After holding the pedal down, undoing the bleed nipple and nipping up again, the pedal went completely to the bottom of travel.
So... I had a quick Google, which told me it looked like the master cylinder. I took the master cylinder to bits, but everything looked fine, ie the seals weren't worn (New cylinders too)
A little bit of fluid came out of the rear bleed nipple when I replaced everything and pumped for 100 x lol.
Does anyone have any ideas? Or is it likely to be the master cylinder?
Many thanks
Jamie
